Max weight rating for a 16" "E" rated tire
Old Oct 24, 2008 | 08:46 PM
cLAYH's Avatar
A friend is buying a toyhauler with tripple 7k axles. The trailer is equipped with 16"LT tires, load rating 'E'. I didn't think 6 'E' rated tires would be enough. Anyone know how many pounds an 'E' tire is rated for?
Old Oct 24, 2008 | 09:17 PM
sewman's Avatar
3042 lbs pr tire @80 psi
Old Oct 24, 2008 | 10:58 PM
cLAYH's Avatar
Thanks!
So 3042# x 6 = 18,252#.
That would be correct is he was getting the stock 6k axles but he is going with the 7Ks. 21,000#. I wonder if the manufacture will up the tires or if its even really needed. The trailer is max rated for 18k, he just want the 7k axles for the added safety factor.
Old Oct 25, 2008 | 02:15 PM
Busboy's Avatar
Don't forget to add in the pin weight, that doesn't count for the trailer tires.
Old Oct 25, 2008 | 09:09 PM
rebal's Avatar
If he has rims that can hold the weight .Goodyear makes a nice LR G #3900 lbs
Old Oct 26, 2008 | 05:59 AM
P Kennedy's Avatar
This number is on every tire eg: 3042@80 psi cold 235/85R16.
Old Oct 29, 2008 | 11:59 AM
nkennedy's Avatar
Michelin 265/75/16 LTX MS are rated to 3415 lbs in single configuration.
Old Oct 29, 2008 | 01:18 PM
southwestwheel's Avatar
DTR Advertiser
An LT or light truck tire is rated for 3042 lbs. while the trailer tire or ST is rated for 3500 lbs. The true trailer tire is an ST23580R16E some are better than others, we prefer the Titan made in the U.S. of A.
Old Dec 7, 2008 | 12:54 PM
diesel96's Avatar
The tire will also show a duel wheel weight rating, that is usually lower.
Old Dec 8, 2008 | 01:03 AM
338Lapua's Avatar
E Rated
Check the tire, not ALL are the same rating. Check manuf. website, or tire sidewall.
Old Dec 8, 2008 | 09:59 AM
jmd025's Avatar
It all depends on size.
E range 235/85/16 is 3042 lbs single, 265/75/16 E range is higher, so forth and so on.
Old Dec 8, 2008 | 10:12 AM
snoyes's Avatar
3520# on the E rated tires on my trailer. Again, they are going to vary....
DTR Advertiser
Bigger is not always better. Make sure the tire is approved for your rim contour. The strongest sixteen inch trailer wheel made is 16x6 3750 lbs. at 110 psi. A 265 tire needs at least a 7" bead seat. The strongest 7" bead seat is 3045 lbs. at 80 psi, unless you get an eastern orient company to put any rating you wish on the wheel.
Kapman02
Jun 6, 2012 08:56 AM
buddy26
47
Jan 4, 2007 08:25 PM
j28s
Feb 14, 2003 04:14 PM
