can't get grease in
Old May 25, 2005 | 01:07 PM
ralphie's Avatar
can't get grease in
I was trying to grease the zerks that are just inside of the front tires. The passenger side was no problem, but I couldn't get grease in the driver's side. I pulled the zerk out and grease will pas through it. Put it back in and no go. Where do i go from here?
Old May 25, 2005 | 01:45 PM
67HotRod's Avatar
I had this happen on another vehicle. Pull out the zerk and see spray the inside with penetrating oil. Put the zerk back in, drive it for a day and try it again. Took about 3 or 4 times before I was able to push grease into it. The other option is replacing the part after it wears out.
Good Luck!
Old May 25, 2005 | 08:06 PM
kandgo's Avatar
There is a tool that is hard to find, it is a cylinder with a removeable drive cartridge that you pull out and fill with penetrating oil and it has a greas zerk head that you slip over the grease zerks and strike it with a small hammer and it will drive pressurized penetrating oil into the area that is clogged. I use them most every day on zerks that are on my dozers that are notorious for clogging. Might try some of the heavy equipment places to see if they carry them. Goodluck,,,Rick
Old May 25, 2005 | 09:05 PM
pind's Avatar
Bobcat Company... yeah the skidsteer loader guys. Sell those grease zerk reconditioning tools. they do work fairly well, even on bobcats, where the headframe pins and bushings are forever having grease issues.
I can't recall the part number offhand, but give it a try.
THe other thing you can do, is try jacking the truck up a bit as you put pressure on the fitting, forcing grease through it, many times that will work. It frees up an area for the grease to flow into.
Old May 27, 2005 | 10:27 PM
Dojman's Avatar
Those grease drivers are a handy little tool around farm equipment too. They work a lot better than they look like they should You might try getting a small pick and digging some of the old grease, dirt, rust, etc. out of there, then take a med. sized syringe w/ a fairly stout ga. needle and try shooting some penetrant in there like that.
Old May 27, 2005 | 10:39 PM
infidel's Avatar
I use one of these $21 wonders on the farm, works excellent.
http://www.babcosales.com/product_in...ducts_id=18591
For the really tuff ones try one of these http://shop.forthefarm.com/catalog/p...products_id=47
Old May 27, 2005 | 11:02 PM
torquefan's Avatar
If it's a tie rod end, clamp a pair of visegrips on the tie rod, and rock it back and forth while applying pressure with the grease gun.
Old May 28, 2005 | 08:29 AM
kandgo's Avatar
Greasezerk buster,,, So that is what they call this tool, Thanks bill I was looking to get a couple more of them as the ones I have had for years seem to come up missing and I am down to one. It seems like I got mine at a farm show. Anyway thanks again,, Goodluck,,,Rick
Old May 28, 2005 | 09:02 AM
berner's Avatar
I have to do this on my passenger lower ball joint that was replaced 40K km's ago. Pain in the butt, but it works.
Old May 28, 2005 | 10:54 AM
bmoeller's Avatar
SHOUP MANUFACTURING CO
145 S WEST AVENUE
KANKAKEE IL 60901
PHONE 815-933-4439
WATTS 800-627-6137
These guys carry them.
Old May 28, 2005 | 12:45 PM
kandgo's Avatar
Thanks
Old May 31, 2005 | 09:22 PM
KennyL's Avatar
Tractor suppy has them too. I picked up one last month.
Totallyrad
Jul 19, 2011 07:41 AM
Forty-Two
Oct 22, 2008 11:55 PM
hopak
Apr 3, 2007 05:05 AM
03quadduallyho
Feb 8, 2004 03:15 PM
