A/C problems
Old Jul 1, 2009 | 02:40 PM
abarnar1's Avatar
A/C problems
Air not working on 98 12 valve. Checked low side pressure and it was around 45 psi. The compressor clutch is not engaging. I jumped the low pressure switch and it would still not engage. Any ideas on what to check next? Any help would be appreciated. Thanks, Adam.
Old Jul 1, 2009 | 04:04 PM
mrclean's Avatar
[QUOTE=abarnar1;2516860] Checked low side pressure and it was around 45 psi. The compressor clutch is not engaging. I jumped the low pressure switch and it would still not engage. Any ideas on what to check next?/QUOTE]
Are you sure it's not engaging? I wouldn't think there would be that much pressure with the comp inop. Anyway, first check the fuses for the AC. If the fuses are good, then disconnect the harness at the compressor. Use a jumper wire and put 12V directly to the comp clutch(no need for the engine to be running for this, you will hear it clicking on/off). If it works, you'll be looking for a break in a wire, if it doesn't, the clutch coil is bad(this would be accompanied by a blown fuse).
Old Jul 1, 2009 | 04:05 PM
patdaly's Avatar
Personally I would put 12V to the compressor clutch direct to test clutch engagement. If it engages, then you know you are heading back to the control system.
Old Jul 1, 2009 | 06:17 PM
abarnar1's Avatar
Thanks for the info. Yes the fuses are good, and no the clutch is not engaging. I will try putting 12 volts straight to the compressor and see if the clutch engages or not.
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
