Brake pad changeout
Old May 1, 2003 | 06:44 AM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
Brake pad changeout
2001.5, 2500, 4x4, CTD.<br>Before I get started on changing the pads and realize I don't have the tools I need, I hereby present the following question;<br>What size and type retaining pins/bolts hold the front calipers in place? Allen, torx, metric, or SAE?<br>Appreciate the info.<br><br>Shortround out<br>
Old May 1, 2003 | 07:51 AM
mymaur's Avatar
Re:Brake pad changeout
2 bolts hold each caliper on. They are 3/8ths hex head, commonly called ALLEN.<br><br>
Old May 1, 2003 | 10:06 AM
shortround's Avatar
Thanks a bunch mymaur,<br>Had a severe brain dump this morning and couldn't remember.<br><br>shortround out
Old May 1, 2003 | 04:03 PM
kingofdodge7131's Avatar
how do you push the caliper back down?<br>
Old May 1, 2003 | 07:00 PM
gkainz's Avatar
I just use plain old C-clamps to push the puck back down.<br>Greg
Old May 1, 2003 | 08:17 PM
Xplorer's Avatar
Just remember to use the old pad w/the clamp. Don't use the clamp on the caliper piston
Old May 1, 2003 | 09:01 PM
Shovelhead's Avatar
Administrator / Scooter Bum
And unscrew the bleeder when you press the piston back so you don't push crud in the lines into the ABS controler.
Old May 1, 2003 | 09:43 PM
Stamey's Avatar
When I compress my calipers, before I loosen anything, I just stick a pry bar between the old pad and the rotor or between the pad and the caliper piston and pry it back in. Geting between the pad and to rotor is preferrable as it evens out the pressure against the piston. Much quicker and simpler than a C-clamp. Has worked for me for 15 years.<br><br>Chris
Old May 2, 2003 | 09:56 PM
Haulin_in_Dixie's Avatar
What Stamey said, been doing that since the disks came out years ago. Just pry them back before you take anything apart.
Old May 4, 2003 | 05:46 PM
shortround's Avatar
Got 'em changed. The retaining bolts were a torx/star type. After spending 45 minutes going through my tool box and a couple other mechanics boxes, I found one that fit. After that it was a piece of cake. Only took about an hour.<br>Guess I'll buy some more tools.<br>Sounds like the start of a new thread. &quot;Tools, the ones I've always wanted.&quot;<br>Hey Top and Gonzo, what do ya think?<br><br>shortround out
gasser76
15
Mar 29, 2011 10:00 PM
OR Mega Cab
Jun 5, 2010 12:26 AM
92smokin blacky
Jun 11, 2009 04:10 PM
Invader
13
Dec 23, 2007 06:09 PM
flyingd
Feb 22, 2004 10:14 PM
