Blend door actuator?
Old Mar 28, 2006 | 05:16 PM
displacedtexan's Avatar
Just verifing what I'm pretty sure about...
My A/C is always on defrost, when I crawl under the dash and move the arm myself it goes to, and stays at the dash vents. If I pull off the vaccum line I can feel it sucking. That means my acuator is bad, right? How much does one run, and how hard is it to change? It looks pretty easy, but looks can be decieving.
Old Mar 28, 2006 | 06:40 PM
Clunk's Avatar
Here's something to check, my '92 had a vac leak at the brake booster...the air went to defrost and the cruise control quit working too until I changed out the power brake booster.
Old Mar 28, 2006 | 06:57 PM
There is vaccum at the acuator though... That is leading me to believe that it is not a vaccum issue.
Old Mar 29, 2006 | 07:44 AM
Clunk's Avatar
I don't know...maybe someone else can chime in.
Old Mar 29, 2006 | 08:25 AM
coalburner400's Avatar
If it moves freely by hand and you've got good vac, I'd say its a safe bet that you've got a bad actuator.
I guess the only thing I could add is to suggest that you add a gauge to the line and see exactly how much vac you got.
I've had slight issues with mine (directional sticks a little so I always get air from the defrost vent). This is because of some chafing on the vacuum line.
I think you're supposed to have 15 - 20 HG but if someone could verify that it would be great.
Old Mar 29, 2006 | 11:26 AM
Eskimo's Avatar
my truck pulls more than 15-20, I'd say that is the BARE minimum..
Old Mar 29, 2006 | 06:10 PM
Stamey's Avatar
I had to replace mine, and I forget, but it was less than 30 bucks.
Chris
Old Mar 29, 2006 | 11:16 PM
Chris
I figured it would be a pretty cheap part... I'm guessing it was fairly easy to swap out? Gracias.
Old Mar 30, 2006 | 06:52 AM
Stamey's Avatar
In my situation, it was just awkward, since it is right above the tranny hump, on the left side. There were only 2 screws, and some kind of clip or knotch for the rod, but getting to them was the pain.
Chris
Old Mar 30, 2006 | 07:19 AM
That's the bugger... I was figurin it was just the 2 screws, and the tab for the rod. If it was a pain for some reason I was thinking I would just have a shop do it.
Old Mar 31, 2006 | 07:46 PM
It didn't take me to long at all to swap it out. Prob 15 min... Thanks Stamey, like the haircut
It was $38, dealer only, if anyone else is having the same problem.
SOhappy
Nov 11, 2011 10:30 PM
billmac
Jun 20, 2010 07:25 AM
mouse70
Jan 20, 2009 01:29 PM
Lost Texan
Aug 20, 2007 11:12 PM
ram23
Mar 28, 2007 05:03 PM
