Alternator problems
Old Nov 20, 2003 | 12:10 AM
Sonora Bob's Avatar
Alternator problems
This morning I was heading out of town with my car trailer in tow, and my "gen" light came on.
I pulled over and the alternator was very hot and even smelled hot. So I went back home.
Well this afternoon I fired it up and it is charging fine.
Any ideas?
Old Nov 20, 2003 | 07:56 AM
jrs_dodge_diesel's Avatar
Re:Alternator problems
Probably starting to go bad on you. Or the voltage regulator. The voltage regulator is usually encased inside the alternator. Next time it happens try and put a voltmeter on it and see what voltage you get. Normal should be around 13.6 to 14.5 volts*. Anything less is bad.
* This is based on my expierience with 12 Volt systems on gas engines.
Old Dec 3, 2003 | 06:45 PM
Sonora Bob's Avatar
Well, it finally happened again.
The generator light came on. But the voltage meter showed nearly 14v. I popped the hood and the alternator was warm, but it had been running awhile. It was not as hot as before.
So I shut it off. Then restarted it. Then generator light did not come on.
Old Dec 3, 2003 | 07:17 PM
kandgo's Avatar
It is giving up the ghost!! Change it out before she leaves you stranded on a dark night, When mine goes I am going to look itno a high output, as for winch and such,goodluck Rick
Old Dec 3, 2003 | 10:14 PM
Sonora Bob's Avatar
But wouldn't the output be down if the alternator was failing?
I have been driving it around for a few days, but I hit the go pedal extra hard and the light came on. Could this be related?
Old Dec 4, 2003 | 09:22 AM
kandgo's Avatar
It could,and it could not,it depends on what is wore out,ie,the regulator,or the contacts??I have had them go from no volts to boiling over the batterys!!Might I suggest to fill out your signature,it helps in answering questions,How old is truck,what model?? Goodluck Rick
Old Dec 9, 2003 | 07:11 PM
Sonora Bob's Avatar
Yup. Just the alternator. Works great now. ;D
Old Dec 10, 2003 | 09:06 PM
Haulin_in_Dixie's Avatar
[quote author=kandgo link=board=5;threadid=22635;start=0#msg217782 date=1070500641]
[/quote]
How high an output do you need? Isn't 136 amp enough? I ran many years with a 60 amp on a big truck. Then up to a 90 amp. A winch does not draw near what the grid heaters do. If you are drawing more than 136 regularly, you need to refigure things some.
joeinnm
Jul 16, 2009 07:46 AM
5.9Excursion
Mar 13, 2008 07:08 AM
jeeptjstud
Dec 16, 2007 11:41 PM
Mike Holmen
Nov 12, 2005 09:49 PM
poolboy
Dec 20, 2002 10:25 PM
