alternator problems
Old Jul 11, 2009 | 06:24 PM
joeinnm's Avatar
alternator problems
I had a positive cable short against the fenderwell. Now my alternator won't charge, I replaced the alternator before remembering this site. The new alternator has battery voltage to the main terminal on the alt. The 2 rear posts show zero voltage. I have checked all the fuses and fuse links that I know of. All the gauges are working as they should, so just I believe that I fried the pcm. Is there a definitive test that I can do or do I just find a replacement pcm? Other options available? What about the adding an external regulator?
thanks for the help
Old Jul 11, 2009 | 06:32 PM
Try swapping the front and center relays in the row of relays on the driver's fender. The front relay is the ASD relay, the center one is the A/C compressor relay. The ASD relay supplies power to the field.
Old Jul 11, 2009 | 10:41 PM
joeinnm's Avatar
I will give that a try, thanks.
Old Jul 11, 2009 | 10:56 PM
sdstriper's Avatar
What year truck?
Old Jul 12, 2009 | 10:26 AM
joeinnm's Avatar
Originally Posted by sdstriper
What year truck?
I'm sorry it is a 92 350 4x4 with a/c
Old Jul 12, 2009 | 11:12 AM
joeinnm's Avatar
on my 92 there are 3 relays on the driver side inner fender, the front and center won't swap, the front and rear do, but it made no difference, I don't know if my a/C was working before or not, it doesn't engage compressor now, but that would not surprise me either, it is on my feed truck that I usually just drive with the windows down.
Old Jul 12, 2009 | 10:09 PM
joeinnm's Avatar
Btt
Old Jul 13, 2009 | 06:58 AM
joeinnm's Avatar
BTT any one with an idea? Did I fry the pcm?
Old Jul 13, 2009 | 08:35 AM
JW's3Dodges's Avatar
I had a no charging issue on my 92 that was fixed by changing the ASD relay, thanks to Dave's input. I picked up the relay from Napa for $6, might be a cheap thing to try. Your AC relay could have been bad and your ASD fried when the short occured.
Old Jul 13, 2009 | 02:30 PM
joeinnm's Avatar
I will give that a try, a guy also told me to get a scanner to put on it, said if it showed rpms, it was the pcm, is this correct?
Old Jul 13, 2009 | 04:50 PM
If you can get an RPM readout from the PCM then it's very unlikely for it to be bad.
Your problem as I understand it is that there is no power to the field when the engine is running, correct?
Old Jul 13, 2009 | 09:13 PM
joeinnm's Avatar
yes sir that is correct, everything else that was working is still working, I have battery voltage to the large bolt, but zero to the others.
Old Jul 14, 2009 | 09:03 AM
joeinnm's Avatar
Btt
Old Jul 14, 2009 | 04:15 PM
It's gonna be a fusible link or ASD relay problem then.
Old Jul 14, 2009 | 07:07 PM
joeinnm's Avatar
all the fuse links were converted to fuses before I bought the truck, I have the ASD relay on order, we have to order everything here, there is a Dodge dealer 65 miles away, but have not heard good reports for service on the older trucks from them. If it wasn't for this website, I would be in the dark.
