70mph shakes
Old Nov 24, 2004 | 04:52 PM
stoneman's Avatar
70mph shakes
I have been thru 3 set of tires and cannot get rid of the 70mph vibration/shakes. It is quite annoying watching and listening to the passenger seat shake from the vibration.
I have had tires balanced 2 times on each set & doesnt help.
Anyone else have this problem?
Old Nov 24, 2004 | 05:12 PM
winkle's Avatar
Could be the divelines out of ballance, it's rare but check to see if any of the balancing weight came off.
Old Nov 24, 2004 | 08:38 PM
JARHEAD's Avatar
I know you have thought about it, but your ball joints are o.k. arent they??? When my joints were bad, it was exactly like the tires were out of balance. It took my quite a while to figure it out. Ruined a set of tires.
Kip
Old Nov 24, 2004 | 09:38 PM
stoneman's Avatar
Brand new ball joints
Old Nov 25, 2004 | 06:30 AM
pappyman's Avatar
Check your ujoints and center bearings if you have them....is this a 4X4 ??.....check your rear tranny mount also
Old Nov 25, 2004 | 07:44 PM
jimk's Avatar
Re: 70mph shakes
My brothers truck had a vibration an it turned out to be a worn transmission yoke a rear tail housing bushing. Good luck Jim
Old Nov 25, 2004 | 09:15 PM
masonic-dodge's Avatar
stoneman
Are all your U-joints in the same plane, if they are out by 90 degrees from one another that would cause a real bad VIBE. Just a thought
CRIS
Old Nov 28, 2004 | 04:54 PM
Richard William's Avatar
You might try your tracking arm. I have gone through 4 on my dodge and it is a 1994 4x4 with 173,000 miles. They are very sh*$y on these trucks.
Old May 20, 2008 | 11:15 PM
rolling18's Avatar
same problem but at 60- 67
i have same problem and feel it only from the seat and see it shake things inside..
so far i have replaced track bar, all ball joints, 2 allignments, 2 tire rotations.
and still looking, next checks are ujoints, tranny mounts,when i figure out how to check them
good luck!!
Old May 29, 2008 | 11:29 AM
roughstock's Avatar
My 97 has same problem, the yoke at back of trans has some play in it, it is only thing I have not replaced.
Old May 29, 2008 | 12:17 PM
justme-'s Avatar
Usually a vibration that comes on at a specific rpm is a balance issue - if you let a bad ujoint go it will thro the drive line out of balance. Could be a joint on it's way out too.
Old May 30, 2008 | 10:39 PM
rolling18's Avatar
welp
I removed the rear driveline and center driveline support bearing (carrier)
now the vibration is gone up to 7o mph (dont wan tto go faster in 4wd)
so the driveline goes in monday to get ballanced, new Carrier, and ujoints all for $220.
that should cure it!!
msatow
190
Jun 18, 2014 06:37 PM
NJMurvin
Dec 13, 2004 10:46 PM
Dufrain
Oct 17, 2004 07:46 AM
jthorpe
27
Sep 22, 2004 06:04 PM
phox_mulder
Apr 30, 2003 03:24 PM
