3/4 ton wheels on 1 ton dually??
Old Feb 24, 2008 | 05:32 PM
thewished's Avatar
I hate having my wheel hit curbs and things, I'd just like to find some nice 3/4 ton wheels but I will still run the same tires. Will this work??
Old Feb 24, 2008 | 09:34 PM
SIXSLUG's Avatar
Are you talking about just on the front? I think the dual rear wheel set up is staged to run with a wider front stance to add stability when towing. I beleive there are spacers on the front hubs that extend the width of the stance. I imagine you could put the flatter offset single rear wheel style wheels on it, but you wouldn't be able to rotate them properly.
Kurt
Old Feb 25, 2008 | 12:03 AM
dozer12216's Avatar
I took the dually front adapters off and used 2500 wheels on front. I'm not sure the studs are adequate. Make sure and use correct lug nuts. This works fine on front. Have to carry extra spare(same as trailer wheels), no big deal for me.
The rear would look sillly with single and dually fenders. Special offset wheel would help.
Old Feb 25, 2008 | 02:00 AM
thewished's Avatar
Yes, I'm just looking to do the front wheels.
What do you mean by front adapters?? Are they hooked to the hub or what?
Old Feb 27, 2008 | 08:47 PM
Ronco95's Avatar
The front rotors are usually just 3/4 ton units with an adaptor on them. The adaptor bolts onto the wheel studs and spaces the wheel mounting surface about 4-5 inches for the dually offset.
The spacer has eight wheel studs on it for the wheel to mount to.
Pull one of your front wheels off and look closely. You will find the eight large nuts, like lug nuts, holding the adaptor on the rotor.
Ronnie
wannadiesel
Sep 15, 2018 01:40 PM
gmctd
Jan 10, 2008 07:43 PM
Jordan5687
Jul 5, 2007 06:24 PM
CTD NUT
Sep 12, 2005 04:40 PM
RobG
Sep 5, 2003 09:13 AM
