2001 steering shock/dampner/stabilizer stud
Old Feb 28, 2006 | 07:34 PM
coalburner400's Avatar
Ok... This question only applies to MY2001 (I've been blessed with yet another part that is unique to this year)
I purchased the stabilizer back at 60,000. I put the shocks on, but noticed that the steering dampener uses a proprietary taper bolt that is part of the shock. Looked around and found that many manufacturers don't make a shock for this year.
Well I still have this stabilizer (heckthorn) and I'm ready/need to put it on. I figured I'd ask if anyone has resolved this proprietary bolt issue, or found a workaround. I'm not interested in getting a bolt and grinding my own taper to it. This item has to be replaced when you replace the shock, I'm assuming DC would offer the hardware.
I hope its not like the Torque Converter. They know that trans fluid has to be replaced yet NOBODY seems to put a mother-grabb'n drain plug on the TC ...
Thanks for your help
Old Mar 2, 2006 | 08:46 AM
bump for an answer
Old Mar 2, 2006 | 09:35 AM
infidel's Avatar
I've ran into the same problem and just used a regular bolt with a locknut.
Old Mar 2, 2006 | 10:10 AM
Thanks Bill
I guess that's my only option. I'll look around for a basic taperbolt... if I find one I'll post the details for others who may have this problem
Old Mar 2, 2006 | 12:46 PM
runamuk's Avatar
My rancho stabelizer came with a tapered bolt specifically for such installation. Check with Rancho I'm sure they'd sell it seperately.
Rick
Old Mar 2, 2006 | 01:28 PM
Crimedog's Avatar
Yeah, I bought a generic stabilizer from Advance Auto and it came with new hardware, including the tapered stud.
Old Mar 2, 2006 | 04:11 PM
Good call... I'll stop by the local NAPA and see what they got... I might get lucky.
Thanks
Old Mar 2, 2006 | 05:10 PM
Gotlift01's Avatar
Well I ended up not being able to get the stock bolt out of mine no matter HOW hard I tried so I just had to cut it off. I got a stablizer bracket that used to U-bolts to hook onto the arm and it worked GREAT!!
~Nick
Old Mar 2, 2006 | 06:23 PM
RedRider's Avatar
ive got a 97 and my skyjacker damner came with a regular 1/2in diameter 3.5in long bolt, but it had a sleeve to compensate for the stock tapered bolt, maybe you can get this same type of sleeve for yours. just throwing it out there.
-Gary
blacklab467
Mar 17, 2012 11:25 PM
EdmontonCanada
Jul 20, 2010 03:57 PM
BamaTJ
Mar 31, 2010 12:35 AM
meanfarmer
Jan 24, 2006 08:57 PM
Scubasteve
Oct 21, 2003 12:46 PM
