2000 Dodge 2500 No Brake Pedal
Old Jun 12, 2015 | 07:13 AM
Firetruckdoctor's Avatar
Angry 2000 Dodge 2500 No Brake Pedal
2000 2500 5.9 cummins 4x4. Replaced front calipers, bled system multiple times, good fluid flow with no air bubbles, as soon as I start the truck the pedal pushes to the floor, pulses twice and ABS & brake light comes on....HELP!
Old Jun 12, 2015 | 01:11 PM
johnh's Avatar
did you bleed the system with the engine running?
Old Jun 12, 2015 | 02:04 PM
No I haven't
Old Jun 13, 2015 | 12:06 PM
SIXSLUG's Avatar
Hydroboost needs to be running to bleed...
If the pedal goes straight to the floor, there is no brake fluid on the ground under the truck and your hoses aren't swelling you still have air in there.
Old Jun 15, 2015 | 07:58 AM
VADSLRAM's Avatar
Also this is a dumb question but are you sure you put the calipers in right?
Right on right side, left on left?
The bleed valves have to be on top or you will never get the air out.
You would be suprised how many "pros" make that mistake.
ACdiesel345
Feb 26, 2009 04:48 PM
jim2000
Oct 21, 2008 08:05 PM
joebishop23
Oct 29, 2007 10:19 AM
shrmpboatcptn
Jan 22, 2007 11:33 PM
mcgeheej
Sep 14, 2006 06:22 PM
