2nd Gen All Products Sell all of your 2nd gen products here. This includes trucks, parts, accessories etc.
Mark this thread as Unsold
Engine & Drivetrain Wanted: nv4500 shift tower
Old Feb 6, 2017 | 09:07 PM
gyman98's Avatar
Looking for a shift tower for a nv4500 also shifter handle would be good too
Old Feb 6, 2017 | 11:56 PM
deere country's Avatar
Their is an early and late version of the shift tower. The early one had a slip on shift lever and the later had a thread in shift lever.
Old Feb 7, 2017 | 09:10 AM
patdaly's Avatar
Yep, early had a push and turn handle retention and 98 up handle assy is retained buy 4 bolts.
Which style do you need?
Old Feb 7, 2017 | 08:05 PM
gyman98's Avatar
Well this one was on a 98 12valve truck if that helps. I'll take a picture of it and post it up.
If they both fit the transmission it doesn't really matter to me which style it is
Old Feb 7, 2017 | 08:48 PM
They do not interchange between the two. If it's a 98 it should be the later style with the threaded shift lever. However if you know dodge well enough you know in a change year like 98 anything is possible, kinda like 1998 extended cab trucks without the rear opening doors. I beleive I saw a picture in your truck thread and if I recall correctly it was the later style but a pic would help clarify it.
Old Feb 8, 2017 | 10:52 AM
patdaly's Avatar
Oh, you are looking for the whole Aluminum assy, complete with handle?
Sorry, I don't have one the whole thing spare......
I believe the Chevy one bolts on as well, if that helps you find one though, they are all 4 bolt threaded rod style.
Old Feb 9, 2017 | 01:26 PM
gyman98's Avatar
Yes I'm looking for the whole thing, the transmission came out of a truck that suffered a cab fire so the shifter was pretty burnt. The boot around the shift tower is melted too. I'm home tonight so I'll take a picture and post it
Also going to post a wanted ad for 2nd Gen manual trans pedal set if anyone has those available too
Old Feb 9, 2017 | 11:02 PM
gyman98's Avatar
Ok here's the pictures, hopefully this helps
Old Feb 10, 2017 | 07:03 AM
That is the '98 and up style and it looks like it was saw-z-alled off just below where the shifter was screwed into it.
You will need a '98 style shifter and base.
I don't have a spare, but at least you know what you are looking for now.
Old Feb 10, 2017 | 08:26 AM
gyman98's Avatar
Ok thanks, the shifter and a bunch of plastic were melted and I just cut it off. In hindsight I probably should of cut it off higher.
It seems to shift ok though, are new dust boots available anywhere? I could just die some threads onto it and make a shifter
Old Feb 10, 2017 | 08:58 AM
That hindsight is a real biatch.
You might easily be able to cut some threads into what is left.
I will E-mail you a picture of a stock shifter stub on a NV-5600 I have in the corner of my shop. The later NV-4500 and NV-5600 both have the same shifter stub design.
Old Feb 10, 2017 | 10:05 AM
gyman98's Avatar
Sounds good thanks Oliver!
thrashingcows
Jan 14, 2016 12:29 PM
thrashingcows
Jan 13, 2016 10:28 AM
CATCRACKER2
Oct 11, 2006 07:06 AM
Dieselcamper
Jul 13, 2006 10:36 PM
shoffs30
Jan 27, 2006 03:37 PM
