Wanted: nv4500 shift tower
Looking for a shift tower for a nv4500 also shifter handle would be good too
Their is an early and late version of the shift tower. The early one had a slip on shift lever and the later had a thread in shift lever.
Yep, early had a push and turn handle retention and 98 up handle assy is retained buy 4 bolts.
Which style do you need? |
Well this one was on a 98 12valve truck if that helps. I'll take a picture of it and post it up.
If they both fit the transmission it doesn't really matter to me which style it is |
They do not interchange between the two. If it's a 98 it should be the later style with the threaded shift lever. However if you know dodge well enough you know in a change year like 98 anything is possible, kinda like 1998 extended cab trucks without the rear opening doors. I beleive I saw a picture in your truck thread and if I recall correctly it was the later style but a pic would help clarify it.
Originally Posted by gyman98
(Post 3320772)
If they both fit the transmission it doesn't really matter to me which style it is Sorry, I don't have one the whole thing spare...... I believe the Chevy one bolts on as well, if that helps you find one though, they are all 4 bolt threaded rod style. |
Yes I'm looking for the whole thing, the transmission came out of a truck that suffered a cab fire so the shifter was pretty burnt. The boot around the shift tower is melted too. I'm home tonight so I'll take a picture and post it
Also going to post a wanted ad for 2nd Gen manual trans pedal set if anyone has those available too |
3 Attachment(s)
That is the '98 and up style and it looks like it was saw-z-alled off just below where the shifter was screwed into it.
You will need a '98 style shifter and base. I don't have a spare, but at least you know what you are looking for now. |
Ok thanks, the shifter and a bunch of plastic were melted and I just cut it off. In hindsight I probably should of cut it off higher.
It seems to shift ok though, are new dust boots available anywhere? I could just die some threads onto it and make a shifter |
That hindsight is a real biatch.[laugh]
You might easily be able to cut some threads into what is left. I will E-mail you a picture of a stock shifter stub on a NV-5600 I have in the corner of my shop. The later NV-4500 and NV-5600 both have the same shifter stub design. |
Sounds good thanks Oliver!
