would I see higher Fuel pressure #'s w/ a big line kit?
Old Dec 19, 2007 | 12:13 AM
greenwing's Avatar
I have a holley blue pump. I put fuel line on to a white plastic hose barb (factory) on the top of tank I think the factory line used to go to this barb?? And have a holley blue mounted on frame rail very close to tank and then fuel line from pump to filter and stock from there on... I'm routed around factory lift pump.... Anyway, I'm seeing f.p. #'s like 10 psi @ idle and 8 psi @ cruising and around 5 @ WOT and just wondered if a big line and or bigger banjo fittings would yield higher pressure readings?? I just have a cheapo stewart warner fuel pressure guage plumbed to the VP.... mechanical guage setup... nothing special....
Old Dec 19, 2007 | 05:45 PM
WestTN's Avatar
Getting rid of the banjo fittings will help a lot. I used the re-locator kit from Geno's Garage.
Old Dec 19, 2007 | 08:18 PM
mini14's Avatar
bigger lines will give u more volume at a lower psi, vp needs volume more then psi it will do just fine @5 psi all the time. when i put 1/2 in line psi droped 5 lbs, with 3/8 line it maintains 15psi @ idle. if your not running high hp u dont need 1/2in lines. and yes getting rid of banjos is a good thing.your psi #'s are good, theres hours of reading if u do a search.
steelblitzkrieg
Nov 26, 2010 12:41 PM
Mechanos
Jan 22, 2009 11:25 AM
scottsjeeprolet
Mar 15, 2007 06:37 PM
ptgarcia
Aug 18, 2006 03:52 PM
jerry007
Oct 28, 2004 08:24 AM
