Fuel pressure and Big line kit.
Old Mar 14, 2007 | 09:34 PM
scottsjeeprolet's Avatar
Well my stock LP went south finally so i deleted it and ran the big line kit to the FF and then to the VP44.
Running the Holley blue i am seeing 10 idle and 6 WOT comp on 5x5. When the LP and Holley were running i was seeing 23 idle and 15 Wot before big line to the VP44.
Is the big line kit responsible for the lower FP readings but now i have more volume to the pump?
So what are your pressures with your big line kit and Holley? Not FASS or Walbro.
Old Mar 15, 2007 | 10:18 AM
stroker4501's Avatar
Big line kit and holley 13 psi idle and i have never seen it go below 9psi I have hot juice too power level six. mario
Old Mar 15, 2007 | 03:44 PM
Sea:\>Drive's Avatar
I know you already know mine but:
Holley Black
Vulcan Big Line Kit
Idle: 10.2psi
Cruise: 9.2-9.8psi
WOT: 8.6psi
Will update once I get my new sender installed too.
Old Mar 15, 2007 | 06:37 PM
S.Dodge's Avatar
I just got my fuel system fiqured out, It finally has good pressure, 25psi at idle and 20 WOT comp on 5x5. I have a holley blue on the frame and a carter 4601HP in the stock location and a big line kit, works great.
steelblitzkrieg
Nov 26, 2010 12:41 PM
Mechanos
Jan 22, 2009 11:25 AM
greenwing
Dec 19, 2007 08:18 PM
ptgarcia
Aug 18, 2006 03:52 PM
jeeptjstud
Jan 26, 2006 06:40 PM
