-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   Fuel pressure and Big line kit. (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/fuel-pressure-big-line-kit-141731/)
scottsjeeprolet 03-14-2007 09:34 PM
Well my stock LP went south finally so i deleted it and ran the big line kit to the FF and then to the VP44.
Running the Holley blue i am seeing 10 idle and 6 WOT comp on 5x5. When the LP and Holley were running i was seeing 23 idle and 15 Wot before big line to the VP44.
Is the big line kit responsible for the lower FP readings but now i have more volume to the pump?
So what are your pressures with your big line kit and Holley? Not FASS or Walbro.
stroker4501 03-15-2007 10:18 AM
Big line kit and holley 13 psi idle and i have never seen it go below 9psi I have hot juice too power level six. mario
Sea:\>Drive 03-15-2007 03:44 PM
I know you already know mine but:
Holley Black
Vulcan Big Line Kit
Idle: 10.2psi
Cruise: 9.2-9.8psi
WOT: 8.6psi
Will update once I get my new sender installed too.
S.Dodge 03-15-2007 06:37 PM
I just got my fuel system fiqured out, It finally has good pressure, 25psi at idle and 20 WOT comp on 5x5. I have a holley blue on the frame and a carter 4601HP in the stock location and a big line kit, works great.
