What Tranny fluid to use in a 47re DTT Trans?
Old Mar 25, 2006 | 05:17 PM
CTD2001's Avatar
I think my fluid is a little low, looking for what i should use top it off. I am currently running synthetic, what should i get? Thanks for the help
Old Mar 25, 2006 | 05:36 PM
CTD2001's Avatar
anyone got any ideas, want to pick some up tomorrow, thanks again
Old Mar 25, 2006 | 06:27 PM
BigBlue's Avatar
DTT recommends +3 or dexron.
Old Mar 25, 2006 | 06:37 PM
Bob Wagner's Avatar
I've ran both amsoil synthetic and now I've been running dextron/mercon. I would not mix fluids.
Find out what you already have in use.
Old Mar 25, 2006 | 06:58 PM
CTD2001's Avatar
alright thanks for the replies, I am wondering what Mass Diesel put in there when they serviced it, i know that it was synthetic, maybe it will say on my receipt, thanks again
Old Mar 25, 2006 | 07:04 PM
CTD2001's Avatar
I just looked at my reciept and all is said was synthetic AFT fluid, how many kinds of synthetic ATF are there? Thanks again
Old Mar 30, 2006 | 11:44 PM
John DiMartino's Avatar
Any synthetic ATF will be fine. There are no complications adding 1 quart to top it off.I know Scott used to use amsoil.....
Old Mar 31, 2006 | 10:38 AM
HOHN's Avatar
What does DTT do to a trans the warrants the use of Dexron versus the stock ATF +3 or +4? Just curious.
I'm a manual guy, so this doesn't affect me, but I'd like to know.
Old Mar 31, 2006 | 10:46 AM
Mike D's Avatar
Bill K. will never tell. I think it has to with the clutch material they use in their rebuild kits.
Old Mar 31, 2006 | 11:28 AM
Wolf_fighter's Avatar
ATF 4 should be used using dextron makes the clutches bite harder but also wears them out faster and ATF 4 can handle hire temps the best thing todo is use lube guard automatic transmission protectant with you trans its $16 a bottle but works miracles www.mlsna.net carries it. we have 3 trucks 47re trans with 300+ k on the trannies all factory original trannies no issues and all of them are trailer rigs
Old Mar 31, 2006 | 02:42 PM
Mechanos's Avatar
There in lies the problem with your recommendation. A DTT tranny is not a factory original. DTT specifically recommends +3 and NOT to use +4. They also state NOT to use any modifiers or additives in the oil without first calling them for approval.
Old Mar 31, 2006 | 06:52 PM
CTD2001's Avatar
I topped mine off with a Quart of Synthetic ATF +4, I was told that +3 was no longer made and that the ATF +4 replaces +3
Old Mar 31, 2006 | 09:17 PM
1timetoomany's Avatar
Same here....no ATF plus 3...only 4...and now it's synthetic...
Old Mar 31, 2006 | 09:21 PM
Abbynormal's Avatar
Look at the ATF on BullyDogs website. Looks like might be good stuff. I may run it after I rebuild my tranny and some of ya'll do my field testing
mar67655
Mar 14, 2009 07:22 PM
chinook9
Sep 9, 2007 05:57 PM
joeybaker82
Apr 15, 2007 06:49 PM
VikingDiesel
13
Apr 27, 2006 11:24 PM
mike6256
Feb 5, 2005 02:28 PM
