water temp rising on a long pull
Old Oct 26, 2006 | 06:47 PM
jaxworks's Avatar
I have a sandrail that I keep in an enclosed trailer and on a recent trip to the sand with the trailer when the weather was warm, I noticed that I was getting a water temp rise when on a long climb and it would drop back to where it normally runs when the road leveled out. Speed did not seem to matter.
On looking things over I noticed that the bottom half of the radiator was partially plugged with the blowby from the engine vent. This truck only has about 60K on it and I am the second owner and I had never really looked that hard down there before.
I used some citrus degreaser and dissolved the gunk and hosed it out and it solved the heating problem. Just thought I'd pass this along.
Old Oct 26, 2006 | 06:51 PM
merrillr4's Avatar
Now all you have to do is relocate that breather so it does not do it again!!
Old Oct 26, 2006 | 06:54 PM
crobtex's Avatar
If you drive off road much, you might want to spray it down again and spray radiators from the backside with something like this. It will get a lot of the dust, dirt, grass, etc out of there.
Old Oct 26, 2006 | 07:22 PM
johnh's Avatar
here's a word of warning, don't use too much pressure as in a pressure washer, it will bend the fins
Old Oct 26, 2006 | 07:35 PM
crobtex's Avatar
This little gizmo does not have near as much pressure as a commercial washer. If you happen to have super high water pressure at your house, note that there is a high tech device on the hose for regulating the pressure.
Old Oct 26, 2006 | 08:11 PM
nitrousn's Avatar
Sounds about normal to me. Diesels always generate more heat when it pulls.
Old Oct 26, 2006 | 11:45 PM
J BODY's Avatar
.....and when you pull your radiator out and really CLEAN IT you'll see it's the only way to fly.
....de-greaser and high pressure, or better yet, a steam cleaner will make it like new.
Old Oct 27, 2006 | 12:10 AM
BigBlue's Avatar
That's gotta be a worse case scenario. I've got 113k on mine and it looks nothing like that and that's after several mudding excursions and what not.
Old Oct 27, 2006 | 01:13 AM
keithw1975's Avatar
I have 140,000 on mine and it doesn't look greasy at all. Just dusty. You been following somebody with engine problems??? :P
Old Oct 27, 2006 | 01:18 AM
Marine's Avatar
Veteran: Marine Corp
The pic of J Body's radiator is on the fan side.
I have my bottle removed, and hose extended, but I am also seeing a rise in temps. I will clean it out when I get back.
Old Oct 27, 2006 | 08:46 AM
J BODY's Avatar
NOT MINE!!! (you could eat off my engine...I'm kind of picky that way)......just one of many I've done at work...and yes, that was a bad high miler. And I believe the "puke" bottle didn't come about until 2000 so you 99 and back guys wouldn't have this issue as bad.
Old Oct 27, 2006 | 08:49 AM
Marine's Avatar
Sorry. I remember when you first posted that pic years ago.
Ed Ventura
Mar 28, 2009 04:58 AM
dnobles
Nov 15, 2008 01:30 AM
Pull Dog
Nov 7, 2008 06:53 AM
jcg
Oct 15, 2008 09:51 PM
