water pump
Old Sep 26, 2008 | 05:29 PM
johnh's Avatar
water pump
i was just wondering how many miles a cummins 24 valve water pump lasts...... mine has just over 200,000
Old Sep 28, 2008 | 10:46 AM
johnh's Avatar
no one? bump
Old Sep 28, 2008 | 10:56 AM
nitrousn's Avatar
I dont think anyone can give you that answer. Pumps fail for many reasons. Poor maintenance is the main cause. Fate is the other.
Old Sep 28, 2008 | 02:50 PM
smokinram99's Avatar
do you have 200k miles w the original water pump?
mine has 89k w factory pump
rob
Old Sep 28, 2008 | 11:03 PM
johnh's Avatar
rob
yes, but i have a spare behind the seat
Old Sep 28, 2008 | 11:56 PM
MikeR's Avatar
There's no set time.
I rebuilt my 12v engine last month, so I decided to change out a perfectly good water pump just 'cause I had it apart. It had 160k on it and still fine, so I'll keep it as a spare.
My friend's '03 crapped the water pump at 50k miles. Go figure.
Old Sep 29, 2008 | 09:11 AM
bentwings's Avatar
I have 201,000 on my OEM pump. Same for the thermostat. Seems fine so far.
Old Sep 29, 2008 | 09:51 AM
cm979's Avatar
288,xxx on the original. I have the same as johnh in the tool box spare pump 4 gallons of 50/50 to go along with it.
Old Sep 29, 2008 | 07:29 PM
johnh's Avatar
the reason asked, every once in a while i can smell antifreeze when i shut it off...... no its not dripping, I'm not losing any coolant. so at this point I'm just waiting for 1 the water pump, 2 heater core, 3 head gasket or something else to start squirting....... then I'll know.
i just noticed under the exhaust manifold toward the rear some stains that could have been caused by coolant
Old Oct 1, 2008 | 07:07 PM
upnya's Avatar
try reading up on the block 53 threads. thats where they crack.
hopefully thats not it. good luck.
Old Oct 1, 2008 | 08:12 PM
johnh's Avatar
yeah, i've been reading about 53 block posts since 2000
Old Oct 2, 2008 | 08:05 AM
nickg's Avatar
OEM orginal water pump here with 497,000Kms on it, at the end of last winter I had the same thing, stink of AF, but it was in the cab, mostly noticed when the heater was on high heat, and when you get in the truck, turned out to be a pin hole in the heater core, never added coolant, and it had been doing this for 6months previous, I delayed fixing it cause it was tooo cold and I could not have my truck down, at the time.
my evaporator was plugged solid with fluff and dirt, after cleaning it I have huge amounts of air flow now, did not realize at the time how bad it actually was
Old Oct 2, 2008 | 10:01 AM
johnh's Avatar
so, i guess my next project is to pull the radiator and inspect , clean, pressure test the heater...
ted_pulliam
Oct 15, 2009 08:24 AM
RamWheelsBy4
Apr 11, 2007 04:43 PM
kev211
14
Feb 22, 2007 03:39 PM
Gene Peterson
Jan 7, 2006 02:32 PM
