Waste Gate Trouble on 2001 on Dodge 2500
Old May 21, 2010 | 09:32 PM
lisagarr1's Avatar
I have a 2001 Dodge 2500 Cummins Diesel waste gate was sticking causing a loss of power on take off. I'm looking for an easy fix. Has anyone experienced this and how did you fix it?
Old May 22, 2010 | 02:38 PM
sheriffav8r's Avatar
Fill out your signature so we know what you are driving. Because if you have an automatic tranny it's not your wastegate but Torque Management that's slowing you down....
Old May 22, 2010 | 08:00 PM
lisagarr1's Avatar
Sorry. Just updated it. It is a 2001 2500 auto 4x4 long bed ext cab. The problem is when i get in it and start it then take off and give some throttle to get into traffic it lags. The rpms will move up slowly and feels like there is no power. After driving a mile or so it will take off and drive fine. It doesnt feel like the trans is slipping. Feels more like a fuel or boost problem. Im not sure where to start. Any ideas?
Old May 22, 2010 | 11:12 PM
bigsmokey's Avatar
sounds like dead pedal needs a injection pump same thing happened to me would start the truck would have no power for the first mile or so then would just start driving normal changed injection pump problem gone sorry they ain't cheap either good luck.
Old May 24, 2010 | 08:36 AM
j-fox's Avatar
The best starting place is to retrieve the codes.
you can do this by cycling the key three times to on and and watching the odo window. write them down and get back to us. It could be a VP-44 injection pump and or the APPS.
Old May 24, 2010 | 08:08 PM
lisagarr1's Avatar
I've already tried the APPS and didn't make a difference. I'll try cycling the key to see what that does.
Old May 24, 2010 | 08:15 PM
lisagarr1's Avatar
OK Just tried cycling the key three times to on and got this code: P 1693. Could you tell me what this is? Thanks!
Old May 24, 2010 | 09:16 PM
kreynolds's Avatar
list of fault codes can be found here.
that one's not in the list though.
here's a thread on the p1693 code.
Old May 24, 2010 | 10:28 PM
j-fox's Avatar
I think that number says there are other codes set. Did you let it time out? It will go back to the odometer.
Codes 0216, 1688 and 1689 are vp codes.
stange
Dec 15, 2008 10:01 AM
powerplant2
Feb 14, 2003 04:36 PM
whiteknight
17
Jan 8, 2003 10:38 PM
ox
Jan 8, 2003 08:41 PM
