Steering pump rebuild?
Old May 23, 2010 | 09:14 PM
Michigan Ram's Avatar
Anybody out there ever rebuild their steering pump? Mines leaking, but don't think it's necessary to buy a new one. Works fine other than the leak.
Old May 24, 2010 | 12:42 AM
nickg's Avatar
likely cheaper for a new pump, IIRC they are only around 80$ canadian.
unless yours is leaking from an o-ring (behind big nut at bottom of pump)where the hi-pressure line leaves the pump
Old May 25, 2010 | 01:02 AM
Big Blue24's Avatar
Rebuild is not too bad if you give yourself a few hours to carefully disassemble so you can reassemble correctly.
As i remember, the rebuild kits run about $25.
csa
Apr 2, 2011 09:14 AM
Begle1
Jul 9, 2005 11:06 PM
grant g
Jan 5, 2004 10:00 PM
rthomas4
Feb 4, 2003 08:49 PM
