Power Steering Rebuild
Old Feb 4, 2003 | 01:53 PM
rthomas4's Avatar
I am trying to find a place that sells a power steering rebuild kit for a 94 dodge 2500 diesel 4x4. Does anyone have any information that might help? Does such a thing exsist? My power steering is leeking pretty bad but I don't want to spend a ton of money to buy a new one if I don't have to.
Old Feb 4, 2003 | 06:37 PM
mechanic's Avatar
Re:Power Steering Rebuild
You don't say what is leaking, but here is what just happened to me.<br>Mine was leaking fluid from the pitman arm shaft. I thought I could just<br>replace the seal there. It leaked worse than ever when I finished with<br>that, and I was pretty careful to not mess up anything. That was about<br>$40. After that, I went to a wrecking yard and got a used one out of a 96.<br>That was $250, because it is from a diesel/heavy duty/8800# gvw rig.<br>If it's just hoses, that should be pretty cheap, and the power steering unit<br>itself probably isn't much either, though it looks like it might be a pain<br>to replace what with the vacuum pump bolted to it.<br><br>Good luck.
Old Feb 4, 2003 | 08:49 PM
Garz's Avatar
I can't remember if they were rebuilds or new, but called the local auto parts stores and found that power steering pumps were reasonably cheap (under $100) with a warranty.
csa
Apr 2, 2011 09:14 AM
Dean Snow
Nov 14, 2007 04:36 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
Begle1
Jul 9, 2005 11:06 PM
