wait to start light
Old Oct 30, 2006 | 08:42 PM
the horseman's Avatar
wait to start light
when i try to start my truck the wait to start light does not come on right away like it use to some times it does not come on for about 10 sec. then it comes on and truck starts like it normaly would. what could be the problem is something about to go out. thanks for any suggestions
Old Dec 23, 2006 | 06:06 PM
Bando's Avatar
I have a 1998 24V truck. It is doing the same thing. It will not start until the wait to start light comes on. For some reason my wait to start light does not come on for about 5 full seconds now. It used to come on right away. Last time this happened, my lifter pump went out. Is this a sign that it is happening again?
Old Dec 23, 2006 | 07:01 PM
nitrousn's Avatar
You two guys need to fill out your sigs so we will know what kind of truck you are talking about..
Old Jan 7, 2007 | 06:29 PM
deuceandahalf's Avatar
What you describe was one of the symptoms I experienced when my lift pump went south followed by my IP.
Bando's Avatar
Good idea! My information is in my signature. Any ideas? Where can I buy one of the lift pump pressure guages, the one that has a warning light you can put in the cab?
Old Jan 7, 2007 | 08:19 PM
ohiostate24's Avatar
I wouldnt get too excited about it until you get the gauges installed. But that is a most do as soon as possible. Mine takes a little longer when its colder outside.
Old Jan 16, 2007 | 09:28 PM
trex's Avatar
im having the same problem. it dont think it is fuel pressure but i need to check it. it seems that the wait to start light cycles the fuel pumps to prime and then it will crank. but if the wait to start light doesnt come on it just turns over with nothing.
mitm
May 20, 2014 12:32 AM
jriggs_18
Jan 11, 2007 04:43 PM
loosendend
Sep 4, 2006 12:01 PM
bfarrell
Nov 30, 2005 03:23 PM
59FORD
Aug 10, 2005 08:09 AM
