Cruise Control
Old Jan 15, 2007 | 09:26 AM
SKINNERBOY's Avatar
Cruise Control
Cruise control doesn't work on my truck. I am looking for a starting point. I was wondering about the clockspring that I have heard about on here. Does anyone have a diagram or instructions on how to get to this piece? Or is there someplace else I should start? Also the seatbelt light stays lit up all the time not sure if this would indicate anything else? Any help would be appreciated
THANKS
Old Jan 15, 2007 | 09:30 AM
P.J's Avatar
P.J
Vacuum leak. I don't know where to start, but other than a blown fuse, you are probably looking for a leak.
If equipped, does your 4WD work?
Old Jan 15, 2007 | 10:03 AM
SKINNERBOY's Avatar
4x4 seems to work fine in hi and low range I can't hear or see anything obvious.Is there a trick to find a leak like this?
Thanks for the help
Old Jan 15, 2007 | 10:08 AM
P.J's Avatar
P.J
Seatbelt light is probably that harness under you driver seat. My 2001 used to flicker all the time, with the belt fastened, really ticked me off.
I went under there and disconnected.re-connected it and giggled it around a bit (you know, the fix all for electrical connections!), worked as it should after that.
Old Jan 16, 2007 | 07:19 PM
Need95-00CTD's Avatar
I'm having the same problem with my cruise...I think its the switch, because the ON switch stays pressed in 99% of the time, and it has 232K miles on it, so thats a lot on a switch that gets used fairly often.
Old Jan 16, 2007 | 07:34 PM
CTD NUT's Avatar
Not to hijack but I have a similar problem.....sometimes the cruise works, sometimes it doesn't. The light comes on the dash but when I set the speed, nothing happens.....checked for DTC's and I get a 1595 "cruise control solenoid circuit A". Does this sound like a potential clock spring issue? I really don't think it has anything to do with vacuum since the problem is intermitent....this DTC leads me to believe it is electrical.
SKINNERBOY and Need95-00CTD,
Do you have this DTC present?
Old Jan 17, 2007 | 05:03 AM
SKINNERBOY's Avatar
No I am showing no codes whatsoever. The one thing I forgot to mention is that my dash light doesn't light up at all. I assume that the word "CRUISE" comes on somewhere like my wifes '00 Durango. Haven't had a chance to dig into this yet.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
sam
Mar 31, 2003 09:04 PM
TexasDiesel
Dec 27, 2002 10:47 AM
