vp44--lift pump
Old Feb 15, 2004 | 07:34 AM
herb's Avatar
vp44--lift pump
is the vp44 and the lift pump the same thing?
Old Feb 15, 2004 | 08:17 AM
Shovelhead's Avatar
Administrator / Scooter Bum
The VP is the Injection Pump.
The Lift Pump is also know as the Transfer Pump and is used to bring an adequite fuel supply from the tank to the Injection Pump.
#1 is the Lift Pump
#17 is the VP
Old Feb 15, 2004 | 09:46 AM
billg's Avatar
The only thing to add to this is, when lift pump ($142.00) goes out it takes out the VP-44 (about $1800.00). It is a good idea to monitor the pressure of this pump.
Old Feb 15, 2004 | 10:12 AM
herb's Avatar
my dealer just replaced my lift pump. does the v 44 always go out when the lift pump goes?
gauges are on order, hope to find someone in the west mich area with knowledge to install them for me.
Old Feb 15, 2004 | 11:43 AM
billg's Avatar
That would depend on whether there was pressure at the pump (but just low) or was the VP trying to suck fuel through the lift pump. If you had positive pressure at the pump and caught it, than you are most likely ok. The VP uses fuel for lubrication and cooling, if it has to pull fuel through the lift pump there is no extra fuel for cooling or lubrication.
Old Feb 15, 2004 | 12:03 PM
herb's Avatar
like i say, i have gauges on order ,so without having gauges before i do not know what was going on. took it in to dealer for lack of towing power up hills ,would not hold in overdrive, excessive fuel usage, and cutting out as if i had shut the key off (engine continued to run just lost it's power) about the time i would get to the top of a grade.
they replaced lift pump injector pump and flashed it for a boost in power in overdrive that supposedly is available for the 2001's.
Herb
Old Feb 15, 2004 | 12:04 PM
Shovelhead's Avatar
It would also depend on the driving conditions when the pump was not operational.
Hard driving, hot temps, or heavy towing could hasten the demise of the injection pump.
Unloaded commuting might not have an effect at all.
Old Feb 16, 2004 | 07:33 PM
magnum's Avatar
Could happen Herb, I lost my lift pump, VP-44 went a week later, that one lasted 4 weeks, and this one??????But I now have a full set of gauges, and everything is ok now.
If the lift pump caused the engine to stumble and lose power, I would suspect that the VP-44 will follow.
Just my .05
Old Feb 16, 2004 | 08:03 PM
amartinson's Avatar
Originally posted by magnum
Just my .05
$.05??
There goes that dang inflation again.
Old Feb 16, 2004 | 08:04 PM
herb's Avatar
leaving for a towing trip tommorrow morning mi to minn to colorado to utah then back to mi so we will have a good opprotunity to see if all is well.
Txwelder
Nov 26, 2025 01:53 AM
adgr71
Nov 28, 2005 07:34 PM
Txwelder
May 19, 2005 06:10 PM
routerguy99
17
Aug 11, 2003 12:21 PM
36
Jun 4, 2003 02:30 AM
