01 dodge fuel gauge problems
i replaced the sending unit and gauge always shows full. take out and move and only goes to half when pushed all the way down. somebody told might be the ground? what colour wire is that? thanks
Cummins Guru
Fuel tank module (diesel) - lt gray 4 way cav circuit function
1 - -
2 k4 20bk/lb sensor ground
3 k226 20db/wt fuel level sensor signal
4 - -
1 - -
4 - -
Cummins Guru
connector at fuel tank module, clean and check all grounds off the PCM. Run ground to #2 at tank connector see if gauge reads properly then. Check resistance of #2 terminal at tank connector. You can also do a instrument cluster test by holding down trip reset button and then turning ign to on position, will check for proper operation of gauges.
i cleaned all the contacts you mentioned. should i check the ohms at the sending unit contact 2 at 20 ohms on the multimeter? that instrument cluster test was pretty cool
nrussell
07-23-2008 08:58 PM
