01 dodge fuel gauge problems
Old May 7, 2011 | 09:21 PM
canadacatalyst's Avatar
i replaced the sending unit and gauge always shows full. take out and move and only goes to half when pushed all the way down. somebody told might be the ground? what colour wire is that? thanks
Old May 7, 2011 | 10:44 PM
BigIron70's Avatar
Cummins Guru
Fuel tank module (diesel) - lt gray 4 way cav circuit function
1 - -
2 k4 20bk/lb sensor ground
3 k226 20db/wt fuel level sensor signal
4 - -
Old May 8, 2011 | 12:06 PM
fuel gauge
i am not really sure if i understand your language there..... could you explain better?
Old May 8, 2011 | 01:21 PM
BigIron70's Avatar
Cummins Guru
connector at fuel tank module, clean and check all grounds off the PCM. Run ground to #2 at tank connector see if gauge reads properly then. Check resistance of #2 terminal at tank connector. You can also do a instrument cluster test by holding down trip reset button and then turning ign to on position, will check for proper operation of gauges.
Old Jul 16, 2011 | 12:05 PM
i cleaned all the contacts you mentioned. should i check the ohms at the sending unit contact 2 at 20 ohms on the multimeter? that instrument cluster test was pretty cool
Old Jul 29, 2011 | 01:08 AM
omarshervo's Avatar
Guess it has something to do with the sending unit.Im on the same boat a week ago or so. The difference was that my auto was totally deteriorated and thus i replaced some parts that deals with electrical aspect. recommend doing the same thing for $40-$50. Just search the specific edit to remove non-sponsor vendor link you need using your fav search engine and lots of them will appear...hope this little knowledge helps
DJ Turbo.
Oct 13, 2011 09:11 PM
1stgenatheart
Oct 19, 2009 06:33 AM
nrussell
Jul 23, 2008 08:58 PM
staken
Mar 5, 2008 07:41 PM
