vp44 and edge
Old Sep 10, 2009 | 10:08 PM
sabo21's Avatar
vp44 and edge
just installed a new vp44 , i have a edge box set on middle setting 62hp , my fuel pressure guage stays above 10psi , is this edge gonna cause me any damage to my new vp?? just want to be safe.
Old Sep 10, 2009 | 10:17 PM
67HotRod's Avatar
Cool
Lots of posts on this subject, untapped I say no. I have a new vp and haven't tapped it yet, have a stealth plate on the shelf waiting.
Old Sep 10, 2009 | 11:32 PM
cread01's Avatar
I have always been told to run them stock for a 1,000 miles or so before turning on the box. But I have never seen on die because they didn't wait. If I was you I would ask who you bought your VP from and see what they say.
Old Sep 11, 2009 | 09:02 AM
sabo21's Avatar
my edge is the ez series and it just plugs in no tapping wires.
Old Sep 11, 2009 | 08:58 PM
Sandman's Avatar
I put a new VP44 on a year ago and tapped the wire immediately, no problems yet. I have never even heard that you should put 1000 miles on it before tapping the wire. News to me.
Old Sep 11, 2009 | 09:02 PM
blue_bandit's Avatar
I have also never heard that. As far as I understand, if your fuel pressure stays put, then you should be just fine.
Old Sep 12, 2009 | 09:07 PM
mysterync's Avatar
VP Failures are related to fuel flow and volume. Tapping the wire has no adverse affect besides loss of warranty on the pump and pre-existing problems with the pumps electronic componets
Old Sep 12, 2009 | 11:31 PM
Barefoot88's Avatar
True that!!!!
kiley
Old Sep 13, 2009 | 03:30 PM
sheriffav8r's Avatar
I tapped mine immediately and have had no problems now for over 20K miles. One thing is weird, though. No matter what setting I have the Juice on (other than "0" Stock) when my engine warms up and the Juice kicks in I swear my VP makes a strange sound. Kind of like the engine noise changes and makes a more grinding noise. Probably just my imagination, though.... I usually leave it at stock until the engine is nice and warmed up....
Old Sep 14, 2009 | 03:51 AM
Silver_Ram's Avatar
The Edge Juice w/ Attitude has built in cold engine protection, you just have to enable it. It turns the chip on, when the truck's coolant temp hits 160 degrees.
Old Sep 14, 2009 | 07:02 PM
sabo21's Avatar
so which is safer ,an edge ez that just pluges into the baro and timing connectors or the type that splices into injection pump wiring?? also my fuel pressure at idle at the vp is 17 psi at wot it drops to 13-14 psi , i guess this type of drop is normal ?
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
JD farmboy
May 21, 2006 01:04 PM
Timmay2
25
Feb 12, 2006 01:00 AM
