vp44 and edge
vp44 and edge
just installed a new vp44 , i have a edge box set on middle setting 62hp , my fuel pressure guage stays above 10psi , is this edge gonna cause me any damage to my new vp?? just want to be safe.
I have always been told to run them stock for a 1,000 miles or so before turning on the box. But I have never seen on die because they didn't wait. If I was you I would ask who you bought your VP from and see what they say.
VP Failures are related to fuel flow and volume. Tapping the wire has no adverse affect besides loss of warranty on the pump and pre-existing problems with the pumps electronic componets
I tapped mine immediately and have had no problems now for over 20K miles. One thing is weird, though. No matter what setting I have the Juice on (other than "0" Stock) when my engine warms up and the Juice kicks in I swear my VP makes a strange sound. Kind of like the engine noise changes and makes a more grinding noise. Probably just my imagination, though.... I usually leave it at stock until the engine is nice and warmed up....
so which is safer ,an edge ez that just pluges into the baro and timing connectors or the type that splices into injection pump wiring?? also my fuel pressure at idle at the vp is 17 psi at wot it drops to 13-14 psi , i guess this type of drop is normal ?
Erska
17
Mar 6, 2009 09:52 PM
JD farmboy
May 21, 2006 01:04 PM
