VP Timing
Old Oct 18, 2007 | 06:35 PM
Hrshoes's Avatar
VP Timing
This may sound like a dumb ? but does the VP need to be timed when it's replaced.
Old Oct 18, 2007 | 06:49 PM
HOHN's Avatar
No. There's an alignment key that indexes it to the gear train. The key can only go in one way, from what I understand.
If you do the install, DO NOT LET THE KEY FALL OUT!
Fishing it out of the geartrain and/or oilpan will ruin your week.
jh
Old Oct 18, 2007 | 06:50 PM
Hrshoes's Avatar
a semi mechanic told me that you have to special alignment that only a mechanic can do cause u can screw the engine up or ruin it
Old Oct 18, 2007 | 08:21 PM
paulb's Avatar
jh
It can go in both ways, but only one way is correct. There is a mark on the key. Good thing you put the disclaimer in your sig!
Paul
Old Oct 18, 2007 | 08:53 PM
Hrshoes's Avatar
So the key is the only thing to worry about, and the electronics take care of injection timing, and other than that is it a problem changing the pump.
Old Oct 18, 2007 | 09:59 PM
nickg's Avatar
The search engine is your friend
Watch these video'....
https://www.dieseltruckresource.com/...2&postcount=55
Old Oct 19, 2007 | 01:56 AM
HOHN's Avatar
Paul
Good catch! I'm wondering if there isn't a secret DTR team out there correcting my misinformation at each turn
Old Oct 19, 2007 | 06:52 AM
gies's Avatar
There is a mark on the key for which way it should point but Hohn is correct, once the key is installed, there is only one way the VP can align. There is no adjustment.
Be careful removing the old pump too - that key is just as likely to fall out. Ask me how I know!
GR40RCapri
Jul 24, 2006 11:47 PM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
