squeaky metallic noise
Old Oct 5, 2007 | 02:00 PM
blake2500's Avatar
Started today, sounds like the metallic vibration squeak like when you pull a small lawnmower trailer down a bumpy road. Braking, accellerating, etc does nothing. Sounds like its coming from the drivers side front wheel or under the door. Any ideas?
Old Oct 5, 2007 | 02:11 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
either brakes worn out and dragging or bad wheel bearings.
Old Oct 5, 2007 | 02:38 PM
Snapper's Avatar
if it changes sounds or stops when turning left or right it's wheel bearings, if not then brake stops are contacting the rotor
Old Oct 5, 2007 | 03:16 PM
blake2500's Avatar
It doesn't do anything when I brake, and I just had them done about 3 months ago. Not any big change when turning either...
Old Oct 5, 2007 | 03:25 PM
JPR Ram's Avatar
My last set of pads went pretty quick. Ok, maybe not as quick as 3 months. But when the did, It would not make noise while braking. Only when driving down the road. Of course the pad dug it to the rotors very deeply AND only on the left side. The right pads had a 1/4 of life left. Intill you do a visual inspection, I wouldn't cross it off the list of "the usual suspects". Huh....wasn't that a great movie? Diffinately one of my fav's.
Old Oct 6, 2007 | 02:33 PM
blake2500's Avatar
well, its not a scratchy sound, more like a rattling squeak. nothing has an effect on it, it sounds like something loose, but its really loud and i cant find the problem anywhere.
Old Oct 6, 2007 | 11:51 PM
duffer26's Avatar
i have the same sound you are talking about and i cant find it almost like it is a worn out bushing or something but i cant find one
Old Oct 7, 2007 | 08:32 AM
mudwisr2's Avatar
Check your front end components (ujoints, etc) for excessive heat after driving for a while. Also, make sure there is not a rock or something wedged in the brake components.
Old Oct 7, 2007 | 08:52 AM
mudman78's Avatar
Also check the u-joints in the front driveshaft. My front shaft was replaced under warranty at 36,000 miles.
Old Oct 7, 2007 | 11:31 AM
duffer26's Avatar
has nothing to do with the brakes at all still there weather on the brakes or not and it is not a scraping sound it is like a metalic moan that dose not keep up with the speed of the truck or anything elts it is not drive train
Old Oct 18, 2007 | 06:49 PM
01ctd2500's Avatar
I too have just heard the same problem with my truck, and when I find it (and I will) I'll post it. Its gotta be the most annoying sound I ever heard. Well, next to a Honda at least.
Old Oct 18, 2007 | 07:37 PM
nickg's Avatar
Mine was doing that and it was the anti rattle shim that had worked loose and slid across and was scraping on the inside of the rim, it had worn a nice groove into my aluminum rim! I actually pulled it out without removing the tire, as the hole in the rim lined up nicely with the caliper
Old Oct 19, 2007 | 08:04 AM
high bid's Avatar
Yep, same squeak squeak noise as I roll down the road. Replaced front driver hub thinking the bearings were going out and had uneven tire wear. Lubed the heck out of everything in the front end and made sure all is tight. It went away for awhile but now I hear it again. Seems to be at slow speeds and anoys the heck out of me. Truck is at brake check now....maybe they can find something.
koondawg
Nov 21, 2012 04:35 PM
dodge em
Feb 16, 2008 05:44 PM
hotdram
Jun 21, 2006 10:24 PM
Ridiculous
Mar 15, 2006 09:26 AM
rockittboy
Feb 2, 2006 04:58 PM
