valve adjustment and injector install
Old Oct 20, 2012 | 02:22 PM
coon-dog7070's Avatar
Truck just hit 200k and so i thought it would be a good time to run the overhead and put a new set of injectors in. Went with a set of Mach 1.6's got them at a pretty good deal. im gonna do the job myself my question to yall is is there a hole in the flywheel housing to put a turning tool in or do i have to turn the engine over with a socket and ratchet on the dampener or with a chain wrench? Just wondering
Matt
Old Oct 20, 2012 | 04:00 PM
Tallguy67's Avatar
A lot of people put a wrench on the alternator and turn over the engine that way - I think you have to turn it backwards. The tool you are referring to is a barring tool. I believe it uses the starter teeth on the flywheel.
Old Oct 20, 2012 | 04:01 PM
BigIron70's Avatar
Cummins Guru
I personally use a fan wrench (36 MM Fan Wrench) can be used and turn the engine over that way. You can only turn in oposite direction of rotation but the engine doesn't care. Just remember to always remove the wrench before starting engine.
Barring tool here
https://millerspecialtools.spx.com/D...?id=1460&gid=7
Old Oct 20, 2012 | 04:03 PM
Tallguy67's Avatar
LOL - experience stops you from doing dumb things but how do you get experience......
Old Oct 20, 2012 | 06:22 PM
Heimie's Avatar
From: Stony Plain, Alberta, Canada (just outside Edmonton)
I pull the breather off the front engine cover, put a socket and a breaker bar on and turn it over with the fuel pump nut. Only go the direction that would tighten it, though, as you will loosen the nut off.
Old Oct 21, 2012 | 08:55 AM
mini14's Avatar
yes ,there is a hole for the barring tool ive used it a few times, tried turning alt. and fan but belt slips, so i bought the barring tool several years ago
Old Oct 21, 2012 | 03:01 PM
Does anybody know ehat intake and exhaust valves you can adjust at tdc #1 and then at tdc #6? Kindof like a valve adjustment guide that way i dont have to go through the whole firing order
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
wap
May 31, 2007 07:47 PM
ShowMe06
Apr 4, 2007 07:08 PM
dhughe2
13
Dec 6, 2006 07:40 AM
