Valve Adjustment
Old Jan 12, 2005 | 08:16 PM
jethroish's Avatar
Valve Adjustment
Valve adjustment isn't in the maint. schedule until 150,000 miles (least that's what local Cummins told me).
Anyone do it sooner/more often?
Old Jan 12, 2005 | 09:19 PM
Hemi Cat's Avatar
I think it depends more on the type of use you put it thru. If you pull loads a lot you should do the valve adjust between 80 - 100,000 miles. If it's just a grocery getter maybe it is OK to go 150,000.. I won't go past 100,000 miles on mine.
Old Jan 12, 2005 | 09:26 PM
Whitmore's Avatar
From everything I have read most folks are checking them around 100k and not finding much deveation
Cheers, Kevin
Old Jan 12, 2005 | 11:03 PM
HydraulicGuy's Avatar
I checked mine at 172000 because I thought I heard some valve train noise. Only one exhaust valve was out about 2 thou. But I did have peace of of mind knowing it was done.
HydraulicGuy
Old Jan 13, 2005 | 08:20 AM
Jetpilot's Avatar
I normally check mine at least once a year....... I have found that there can quite a bit of variance on the lash from cummins.
Doug
Old Jan 14, 2005 | 07:28 PM
popeyesides's Avatar
I just did mine last week at 90000,sure made a abig difference,motor is a lot smoother and quieter,It took about 1 hour.I set mine on the tight side.
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
