Valve Adjustment
Old Jan 27, 2003 | 07:37 PM
Kimrey's Avatar
Valve Adjustment
Can anyone tell me when I should get my valves adjusted on a bombed truck. I have a valve or two thats making unusual ticking noise. I can hear it better when you shut the truck off. You know the last second before it stops, after you turn the key off. I have 60k on her now, and i have been noticing this the last 3-5k. Could it be the cold weather as well? Any help would be appreciated. Also, is there a particular setting they need to be at, or factory spects? I'm ignorant to valves.<br>Thanks,<br><br>Kimrey
Old Jan 27, 2003 | 07:53 PM
NAIL BENDER's Avatar
Re:Valve Adjustment
I just checked my valves last weekend. I have 74K miles on my 99 and everyone of them was within 2degrees. First valve adjust.
Old Jan 27, 2003 | 07:59 PM
Kimrey's Avatar
Re:Valve Adjustment
2 degrees? Is that good?
Old Jan 27, 2003 | 08:22 PM
DEZLPWR's Avatar
Re:Valve Adjustment
I did my first valve adjust with Nail Bender and I had 93K on my HEAVILY bombed (see sig) '99. ALL valves were within spec, although we did adjust the 2 intake valves on #'s 5&amp;6 as they were a little close for my comfort to being out of spec.... <br><br>YMMMV 8)<br><br>Can't hurt to check though, and put your mind at ease!
Old Jan 27, 2003 | 09:50 PM
BigK's Avatar
Re:Valve Adjustment
That'd be a couple of thousandths there, NB. <br>Cut him some slack folks, he's a gearhead in training. ???<br><br>I have adjusted @ 75k intervals, but previous trucks have been stock. If I were to put some power in, I would decrease my interval, but only for good measure. This valvetrain ain't no small bolck Chev. <br><br>If you have done this sort of work before, you'll find it to be quite simple. I would recommend a service manual. It will provide you w/all the info, specs, and tools needed for the operation.
Old Jan 27, 2003 | 09:58 PM
scottrod's Avatar
Re:Valve Adjustment
I did mine at 15k miles when I did injectors. I set the intakes at .010 and the exhaust at .020<br>
Old Jan 28, 2003 | 05:52 PM
Kimrey's Avatar
Re:Valve Adjustment
Ok, now I'm really confused ??? What is best, factory or like spark chaser set his?<br><br>Kimrey
Old Jan 28, 2003 | 06:19 PM
scottrod's Avatar
Re:Valve Adjustment
I believe mine are well within factory specs
Old Jan 28, 2003 | 09:43 PM
Re:Valve Adjustment
[quote author=BigK link=board=4;threadid=10163;start=0#97252 date=1043725825]<br>That'd be a couple of thousandths there, NB. <br>Cut him some slack folks, he's a gearhead in training. ???<br><br>I have adjusted @ 75k intervals, but previous trucks have been stock. If I were to put some power in, I would decrease my interval, but only for good measure. This valvetrain ain't no small bolck Chev. <br><br>If you have done this sort of work before, you'll find it to be quite simple. I would recommend a service manual. It will provide you w/all the info, specs, and tools needed for the operation.<br>[/quote]<br><br>Thanks for the correction Big K, yes I am new, sorry for the mis-statement.
Old Jan 28, 2003 | 10:45 PM
DEZLPWR's Avatar
Re:Valve Adjustment
I am also a newbie in training.... <br>BigK is pointing me in the right direction though! ;D
Old Jan 28, 2003 | 10:58 PM
Kennys's Avatar
Re:Valve Adjustment
I waited until I installed 275 injectors at 190,000+ to adjust mine. They were all within specs, some were about .003 from center of specs. Not bad for the miles. Kenny
Old Jan 29, 2003 | 12:55 PM
Marine's Avatar
Veteran: Marine Corp
Re:Valve Adjustment
I did mine at 45,000 miles. All were within spec, but all throughout the spec. I tightened mine down to min. spec.<br><br>Mike
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
