valve adjustment
Old May 31, 2007 | 09:13 AM
skeeter 99's Avatar
valve adjustment
I have a couple questions about the valve adjustment.
why did they turn the engine over counter clock wise
why not hook up a starter button.
and could you adj the valves with the engine running and due one cyl at a time
last question if you had a 89 truck how worried would you be about the pin
in the cam falling out
Old May 31, 2007 | 09:46 AM
John Faughn's Avatar
My guess on the CW is to use the ALT. nut ,
The stater button is to hard to stop on just the right spot .
I've done with eng. running on performance gassers , used clips that went on rockers to keep oil from spraying every were .
The pin I'm not familiar with .
Old May 31, 2007 | 11:18 AM
coachgrowl's Avatar
https://www.dieseltruckresource.com/...prog=1&lang=en
I used the above link it is very helpful.
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
bulthisl
Mar 22, 2003 07:01 AM
blackboat
Nov 8, 2002 06:32 PM
