Upgrade to medium duty trans.. anyone?
Old Jan 16, 2008 | 07:08 AM
safehaul's Avatar
I am pushing my NV4500 way too far and its costing me.. I lost 5th and had it rebuilt at ammco for $3k.. 2 weeks later I screwed up and hauled 30k for 1400 mikes.. 2 weeks later 5th is vibrating.. I bet ammco doesnt warranty it but who knows.. Its on the road now driving in 4th @ 60mph..
So I have decided that I have 2 choices. 1) I shut down my business
2) I move this wonderful truck up to a medium duty transmission and all my problems will be gone.
Also; there is a very good reason I dont move up to a medium duty truck.. three letters C D L.
So... I am wondering.. has anybody every done this? There are many options out there.. I'd like to pick the cheapest trans out there. I am sure I could find something used for under $1000 and put it to work hauling much less than it was designed for.. but I have no idea what my options are. I realize this will take some fabrication.. okay a lot of fabrication and machine work.. but that is fine and I will do most of the work myself..
It would be nice if I could find someone who has done it before so I know what I am in for..
Old Jan 16, 2008 | 08:03 AM
Tocapet's Avatar
Is a CDL THAT hard to get? Seems like that might be your best option.
Old Jan 16, 2008 | 08:10 AM
haloman's Avatar
2wd would be easier than 4wd. Probably will have to modify the trans tunnel.
Old Jan 16, 2008 | 08:19 AM
safehaul's Avatar
Its part of my business plan to not have CDL drivers.. I'd rather not get into that if you dont mind.. Just trying to get this truck fixed. After researching I see I posted in the wrong place.. I should have posted under performance.. there is a bit of communication there about doing this.. but mostly auto's.. I want to stick to manual I think.. seems like it would be way more economical.. my other option I guess is to call ATS and see if there rebbuilt NV4500's are up to the task.. sure wish I didnt have to repair mine on the road.. could have bought a ATS.. what a bummer.
Old Jan 16, 2008 | 08:20 AM
safehaul's Avatar
Yes, mine is a 2wd 3500.. 1999. I guess I need to figure out which transmissions were fitted to the ISB in the freightliners.
Old Jan 16, 2008 | 08:32 AM
haloman's Avatar
They had eaton 5spds and 6spds IIRC.
Old Jan 16, 2008 | 08:36 AM
safehaul's Avatar
Yeah I am just reading that now.. I guess I could buy everything I need from a salvage yard.. just find a blown 5.9l ISB and buy the bellhousing back maybe. Shorten the driveshaft, build the mounts for it... deal with making the clutch work and that should do it.. should just take $5k and a months work.
Old Jan 16, 2008 | 08:52 AM
CTD NUT's Avatar
The end of your problems seems like a much more straight-forawrd NV5600 swap....I'm not understanding why you wouldn't go that route? It is a much more durable tranny for hauling heavy and the extra gear really tightens up the ratio spread - another benefit for hauling heavy.
Depending on the med. duty tranny, there are going to be some fitment issues with the overall height of the tranny case and shift tower.
Old Jan 16, 2008 | 09:06 AM
safehaul's Avatar
Nah, the NV4500 is rated for 21,000 GCVWR, the 5600 I thinki s rated for 23 or 24k.. I commonly pull about 25k.. its not rated for what I do. I need something rated over 26,000 GCVWR.
Old Jan 16, 2008 | 09:16 AM
CTD NUT's Avatar
Ok then....
The nearest I can tell, NV5600's seem to be hauling very heavy and reliably at 500+ hp input power. They certainly have a proven record hauling past the OEM GCVWR ratings with well above stock power.
Am I missing something or is that not good enough? From your limited description of your application, you do not appear to be doing anything different than many hotshotters and car carriers that gross out heavier than you. You must remember that the 5600 is quite a departure from the 4500, is nearly twice as heavy and is about as large a transmission as you can reasonably expect to fit in a 2nd gen Ram without extensive modifications.
Old Jan 16, 2008 | 09:30 AM
safehaul's Avatar
Ok then....
Well, I guess I better start looking at that trans then.. but I guess I dont understand how it could work for me rated under what I pull?
I am scared to death to make a mistake at this point. I mean if the trans doesnt hold up I might as well take $6k and toss it out my window and watch it blow away.
I was just looking at this product:
http://www.gearvendors.com/commercial.html
and it seems interesting.. basically it would allow me to stay on the planetary gears of my NV4500.. 1-4 seem to be fine.. its the **** overdrive that is the problem from what I can tell. I dunno.. doggone it.
Yeah I am a car haul just like everyone else.. cept I do not drive and I want to hire older guys that do not have a CDL.. it has been working out fantastic..
I'll look into the 6 speed then.. thanks.
Old Jan 16, 2008 | 09:33 AM
safehaul's Avatar
I was wrong.. the nv5600 is rated for 26,000 GCVWR.. maybe I will go with it.. **** its pricey.
http://dodgeram.org/tech/transmission/nv5600_spec.html
Old Jan 16, 2008 | 09:35 AM
signature600's Avatar
Personally, if you're tearing up NV4500's, I would stick to your idea of the Med duty tranny...the NV5600 is nice, and I'm sure it will handle it, but I'll bet it would be about as cheap to find everything you need out of a Freightliner or some other MD truck.
Chris
Old Jan 16, 2008 | 09:43 AM
safehaul's Avatar
Chris
Yeah.. I tend to agree.. I do not want any more problems.. getting stuck in the middle of missouri just really really sux. You are at the mercy of any repair shop.. although, I have to say they did it reasonable.. and I think the problem we are having now (bad vibration in 5th) is MY fault.. I should NOT have taken that 30,000 load.. STUPID.. I wasnt' thinking and was desperate for a load.. stupid stupid stupid.
If I could find a salvage yard I bet I could have the whole thing for $2k.. maybe.. those transmissions are WAY cheaper than the nv5600.. WAY cheaper from what I can see..
Old Jan 16, 2008 | 09:49 AM
haloman's Avatar
Another thing to look at is. NV5600's aren't made anymore. Therefore hard to find parts. Stick with the medium duty idea.
