unusual shift problem
Old Jun 15, 2005 | 09:16 PM
addecus's Avatar
Question unusual shift problem
truck runs fine except after startup, it does a longer than usual 1st to 2nd shift. after that first time it will shift normally till truck is shut down, then it will do it again only the first shift cycle after startup. trucc can be cold or hot. it only does this the first sequence after startup then it will shift normally as long as it is not shut down. please help us. edit to add, it didn't do this before last thursday.
Old Jun 24, 2005 | 10:00 AM
addecus's Avatar
weekend bump
Old Jun 24, 2005 | 10:50 PM
Walt L's Avatar
try the apps reset. unhook the batteries, key turned on, step on the throttle n let up. let sit for 30 minutes with the key on. Then take the key out, reconect batteries, turn the key to the on/run possition(do not start), slowly press the go pedal to the floor and let up, turn the key off. your done. start her up and see if that helped.
Old Jun 25, 2005 | 02:46 AM
addecus's Avatar
Thanks for the reply Walt. I tried that when it first happened and am goingto try it again this weekend. Maybe it'll help if I leave the batteries unhooked overnight.
Old Jun 25, 2005 | 06:46 AM
Rauschbo's Avatar
...try doing your warm-up in neutral, this (I've been told) gets the tranny fluid circulating; True or not, it solved the issue for me....
Old Jun 25, 2005 | 07:44 AM
Tiny's Avatar
It does sound like fluid is cold, when is last time it was changed?
Old Jun 25, 2005 | 11:53 AM
Clunk's Avatar
I don't know if this applies to late model trucks but I did the neutral shift right after start thing and waited for the oil pressure to get up before leaving...gave the torque converter a few seconds to fill on my '92 for 4 yrs.
It just got to be a habit ...I didn't mind the additional start-up chore.
addecus's Avatar
even after driving all day if i stop and turn off the key for just a second, it will hold that long first gear shift that first cycle after startup. then it will shift normally as long as the truck is not shut down. Bill from DTT told me to try getting the proper adjustment on the kickdown cable and if that doesn't solve it, replace the solenoid and transducer in the tranny. the parts should be here next week.
Old Jun 27, 2005 | 05:19 PM
Walt L's Avatar
Oh, by the way when you do a apps reset, wait until all your dash indicator lights go out before you start to depress the throttle petal.
Old Jun 29, 2005 | 11:52 PM
addecus's Avatar
well... parts got here today. no problems changing them out. got six quarts of fluid and a new filter... same shift pattern. next stop, dealer?
Old Jun 30, 2005 | 11:21 PM
addecus's Avatar
ok got scheduled with the dealer for the 6th. i really didn't expect too many answers because a search back to the beginning only turned up one occurence of the exact same problem and no one, not even the webmaster knows what happened to the guy (i think his name was ebhern or something close). hope the solution is a reflash or speed sensor you know not to much $$.
Old Jul 5, 2005 | 09:00 AM
Erksnow's Avatar
Make sure to let me know whats going on with it because my 99 does the same thing shift from first to second holds the RPM for a long time before finally shifting
Old Jul 8, 2005 | 09:50 PM
addecus's Avatar
trans output speed sensor was no good.
Old Jul 10, 2005 | 09:11 AM
dreamdrummr's Avatar
Where is this sensor, and is there any way to test these? Is it an expensive part?
Old Jul 10, 2005 | 11:40 PM
addecus's Avatar
trans output speed sensor , located drivers side rear(tailshaft housing) $25.00 should throw a P0720 code. the day we took ours to the dealer, they couldn't do diagnostics because all available techs were doing other vehicles. i told them we would reschedule and took the truck home. just on a try and see effort i changed the sensor (5 minutes) and said a prayer. prob solved.
p0wd3rp1l0t
Apr 1, 2012 02:34 PM
diesel96
Apr 18, 2011 10:34 AM
ado2b1
Dec 5, 2008 06:25 PM
blacklab467
19
Jul 26, 2008 12:56 PM
DPG
Mar 27, 2003 08:30 PM
