Turning the engine with the alternator
Old Jan 22, 2008 | 03:59 PM
Grider Pirate's Avatar
I'm about to check the valve lash on my '99, and the tech article mentions using the barring tool, or turning the engine by rotating the alternator counter-clockwise and letting the belt turn the engine. Anyone have any horror stories or even difficulties getting the engine to rotate using the alternator method? The barring tool is only $40-ish, and I intend to keep this truck pretty much forever, but I'm REALLY Cheap, and, well, 40 bucks is 40 bucks!
Thanks
Old Jan 22, 2008 | 04:06 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Another easy, cheap way is to remove the torque converter/flywheel inspection cover, which is just behind the oil pan sump, and use a large flattipped screwdriver to turn the fly wheel using the teeth and the bottem of the bellhousing. It turns real easy. But you'd need a second pair of eyes up above to help.
Old Jan 22, 2008 | 05:33 PM
PaulDaisy's Avatar
I turned the engine dozens of turns by the alternator nut when replacing my VP44 and bleeding the lines and had zero problems. It is very easy to do.
Old Jan 22, 2008 | 06:48 PM
Thanks! That'll save me 40 bucks!
Old Jan 22, 2008 | 07:24 PM
mini14's Avatar
i tried the alternator and it didnt work for me, the belt sliped, i bought the baring tool works great.
Old Jan 22, 2008 | 08:52 PM
afoulk's Avatar
If you put pressure on the longer section of the belt coming off the alternator with your hand, it will usually grip enough that you can turn the engine over.
Old Jan 22, 2008 | 08:54 PM
bnold's Avatar
Have used the alternator trick on many engines with no issues... However on one truck the compression was high enough that the alternator nut actually came off before the engine moved! Had to use the barring tool then
Old Jan 22, 2008 | 11:10 PM
PaulDaisy's Avatar
I think the whole idea of turning the alternator nut is that you turn it in the tightening direction?..
Old Jan 23, 2008 | 09:39 PM
dozer12216's Avatar
Turn counter clockwise and rotate engine backwards. Real easy if nut is tight enough.
Old Jan 23, 2008 | 09:42 PM
bnold's Avatar
Belt slips in that direction, you have to turn the motor over backwards...
Old Jan 24, 2008 | 12:34 AM
AKcruiserfreak's Avatar
I agree that the motor can be turned over witht the alternator, but if you have the $$, just get the baring tool. Just my $.02
TK
Old Jan 24, 2008 | 01:31 AM
Smkndzl's Avatar
or use a 15 mm socket and long half inch rachet and turn it from the balancer bolts to the crank , works for me
Old Jan 24, 2008 | 03:56 AM
Erska's Avatar
Why in the world you don't turn it on the damper bolts?
5.9Excursion
Mar 13, 2008 07:08 AM
tlmac
May 14, 2005 11:16 PM
rico334
Sep 4, 2004 08:28 AM
fbaron3
14
Jul 12, 2003 12:01 AM
