turbo whine
turbo whine
my turbo has recently started whinning on acceleration, is it time to start shopping for a replacment?
what do you guys reccomend?
it is a stocker and not planning anything major but would like to improve over the stock turbo
thanks for the advice!!
best thing to do, if you are concerned about your turbo, is to take off the elbow going to the air box, and you can grab the end of the turbo shaft, wiggle it around a bit, feeling for play (up, down in-out) if there is play in the bearing then it's time for a rebuild, or a new one. I am not quite shure on the specs for the endplay though.
I usually say if it has movement (espically when from side-side/up-down) it's most likley worn out.
There's a very nice guy who owns and operates Bell Turbo. That's all he's done for many years is design and rebuild turbos. All kinds of turbos. His name is Pius Eberle. Give him a call and he will give you advice and probably steer you with good information.
Link:
http://www.merchantcircle.com/busine...o.541-757-7580
Or:
bellturbo@comcast.net
Link:
Or:
Not necessarily. Talk to some aftermarket, High Horsepower Turbo Manufactures about shaft play in the turbos. Some will tell you they have certain amount of shaft play to allow higher hp engines (higher engine oil psi) to pass through he bearings. Side to side and up down is generally OK as long as the fins are not hitting the housing. In/Out shaft movement is bad, which is a result of your thrust bearings gone, which then the turbo should be replaced or rebuilt.
since brand new mine has had side to side play. i've got an IHI on the rail and it also has side to side play. ball bearing turbos have to have some play or they will tend to seize when hot. at least that's what i've read.
http://www.holset.co.uk/mainsite/fil...nal%20info.php
one problem with checking side-to-side movement when the truck is not running is that there HAS to be some room for the journal bearings to work right. the pressurized oil that allows the shaft to 'float' in the housing needs a little room. if you want the right numbers, get the right specs and measure it properly! a turbo is an expensive part to guess about...
just my 2 cents, but i like my money!
In my experience a whine isn't generally the turbo's fault, it's usually a small air leak somewhere in the plumbing that whistles when the pressure comes up.
There has to be room for the oil to form a wedge and lift the journal off the bearing. If you have zero clearance, then you have zero room for oil to come in and lube and cool it. Then you will have a very hard-to-turn turbo very soon. Radial play is ok, as long as there is zero contact between rotating and stationary parts. Axial play should be almost non existant on these.
The design is just like a high pressure turbin pump. The impeller slides all over the place until you turn it on and it pumps the liquid, the liquid on both sides of the impeller hold it steady.
