Turbo Leak.
Old Sep 23, 2009 | 09:52 PM
blacksmoke99's Avatar
Turbo Leak.
Blew up the turbo last month and replaced it with a used one with 80,000 miles and no shaft play. I noticed when i atarted building boost it sounds like I have a boost leak. I pressurized the system and noticed it's leaking from the back of the compressor housing where the big snap ring holds it together. Wondering if you guys have any thoughts or opinions on a fix.
Old Sep 24, 2009 | 09:49 AM
OlBlue's Avatar
That's common, and there's not much of an absolute fix available as far as I know. You can take the compressor housing off, smooth the flat face on the center section and the mating face on the compressor housing to get rid of anything that is holding them "slightly" apart. Use a greenie or something very similar to keep from scratching the surfaces.
Before you take it apart, run your finger around the back side and try to locate the area that's leaking, then make sure some of the snap ring is over that area instead of the gap.
When reinstalling the snap ring, take a punch and hammer to the snap ring. Tap on it outward to help it seat into the compressor housing all the way around. With the turbo installed, there's are directions where you just won't get a hammer swing. Also, tap the punch with the hammer. You should be able to get it sealed up to 20psi or so, then only slighly leak after that.
Old Sep 24, 2009 | 12:04 PM
Thanks OlBlue, I'll give that a try this weekend and see if that helps.
Old Sep 27, 2009 | 08:02 PM
Tried cleaing up the surfaces and tapping the snap ring in with a punch and it still leaks. Wondering if it would be o.k. the use a real small amount of copper rtv to help seal up the leak?
Old Sep 28, 2009 | 11:05 AM
OlBlue's Avatar
That's some work to go through and not have it succeed. Sorry!
There should be an alignment pin in the back plate that fits in half round "slot" in the compressor housing. Did you notice if that pin was there?
I've heard of people using sealants to stop the leak, but I have not done it. You might take that wonderful snap ring off again, and rotate the compressor housing on the backing plate a little bit to "score" the aluminum housing with what ever is keeping it from sealing. Smooth that out and apply a high temp sealant to make sure this time. The silicone is going to make it no fun to take apart next time.
Old Sep 28, 2009 | 08:28 PM
Just got done tearing it apart and putting it back together. Turns out someone has had the turbo apart before. It was clocked wrong and the alignment pin was pushed all the way in. Got it siliconed and clocked correctedly. Gonna let the silicone cure overnite and see if that helps. Good news is that I can get the turbo out in less than 10 minutes now! Thanks for the help OlBlue!
Old Sep 29, 2009 | 10:50 AM
OlBlue's Avatar
10 minutes? Congrats! I fiddle around with the snap ring alone for what must be 10 hours!!!
Old Jul 7, 2010 | 08:27 AM
mkehler's Avatar
Having the same issue, have a slight leak where the retaining rings 'ends'. I tried clocking the ring back and forth and even the comp housing, but still leaks. Did your silicone work or just eventually burn out? I may try good 'ol old axle bearing grease, I've used it on turbo flanges before with success.
zig100
Mar 18, 2010 03:39 PM
george7941
Nov 28, 2009 09:28 PM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
