Trucks losing Power...
Ok While Driving Along The Truck Will Start Losing Power Let Off The Pedal Hit It Again It Will Come Back And Run For Awhile Then The Check Engine Light Comes On....In A Few Days It Goes Off...
Do the rpm's drop like it's idling? Try resetting your APPS and see how that goes. I too have the same problem. Have u noticed an fluctuating idling every now and again? I reset the APPS and it hasn't done it for a few months now but it still fluctuates every so often just not nears as bad. I can't afford a new sensor just yet.
Tried Unpluging The Batteries For 30 Min That Didn't Help.
Yes The Rpm Drops Like Its Idling Hit The Thottle Again It Ok For Awhile... Thanks
98 Dodge 3500 Quad Cab 4x4 Auto 8' Box
Same problem I have. I don't know what else to tell u other than the APPS. You will have to reset it and not just unplug the batteries for 30 min. You can find the instructions in the tech facts at the top. Just disconnecting the batteries won't reset the APPS. I'd try this first and if it doesn't help then I'd buy a new APPS.
spend the $290.00 for the apps and then it wont happen gain for a long time,recalibrating helps it but doesnt fix it, ive replaced 3 of them on my 2001 but i have a190,000 miles on it, good luck
Alaska Sunrise
05-08-2009 04:11 PM
