Truck quit code ?'s
Old Feb 4, 2008 | 07:03 AM
SKINNERBOY's Avatar
Truck quit code ?'s
Friday on the way home i was rapping on my truck pretty hard in the snow,all of a sudden it sputtered and died and the cel came on instantly. I pulled the codes yesterday and got a p0236 overboost I think? and also it gave me a p0252 I cannot find this code in my book. It shows a 0251 and a 0253 in the book and has to do with the fuel injection pump. Can anyone help?
Old Feb 4, 2008 | 02:45 PM
SKINNERBOY's Avatar
Anyone?? I am lost without my truck
Old Feb 4, 2008 | 04:48 PM
2500Ram's Avatar
Not a dodge site but found this
P0252 has 2 entries :
Fuel Valve Signal Missing :
Problem sensed with fuel circuit internal to fuel injection
pump.
VP44 stuck fuel valve error :
Fuel solenoid circuit not detecting solenoid valve movement
and this
PO252, Fuel Valve Signal Missing
When Monitored : After current monitoring is complete. Average engine speed is above 700 RPM's.
Set condition : The ECM does not recieve a signal from the solenoid valve indicating valve movement.
Diagnostics :
With the DRB erase ECM DTC's. Test drive the vehicle.With the DRB read ECM faults.
Is the DTC PO252 present?
NO, Test complete
YES, Replace the Fuel Injection Pump in accordance with the service information.
post 2 http://www.turbododge.com/forums/f11...p-install.html
Good luck.
Old Feb 5, 2008 | 04:53 AM
SKINNERBOY's Avatar
Thanks I tried again last night and it definatly is not pumping any fuel. This is a bummer I just replaced the VP44 in November. Thnask for the help.
Raspy
Mar 23, 2005 12:47 PM
silverram323
Oct 20, 2003 01:04 PM
gs
May 6, 2003 11:08 AM
MoParr
Feb 22, 2003 04:57 PM
MoParr
0
Feb 16, 2003 01:26 AM
