-20 F. Truck quit. Won't start!!!
Old Feb 15, 2003 | 11:35 PM
MoParr's Avatar
??? My Dodge 2500 quit going down the road yesterday. Thought it may have been jelled up. Tried ghanging the fuel filter and adding conditioner. Checked for fuel flow at bleed valves and I have fuel flow. Had block heater plugged into a generator for 5 hours. Still won't start. Any suggestions would be greatly appreciated!!!
Old Feb 16, 2003 | 11:48 AM
rich's Avatar
Re:-20 F. Truck quit. Won't start!!!
Need a little more info are you getting exhaust smoke when it cranks, does it crank fast or slow
Old Feb 18, 2003 | 02:49 AM
ProspectorTim's Avatar
Also make sure the air filter box isn't full of snow or ice.<br>
Old Feb 22, 2003 | 04:57 PM
jamiebah's Avatar
[quote author=MoParr link=board=13;threadid=11026;start=0#105231 date=1045373723]<br> ??? My Dodge 2500 quit going down the road yesterday. Thought it may have been jelled up. Tried ghanging the fuel filter and adding conditioner. Checked for fuel flow at bleed valves and I have fuel flow. Had block heater plugged into a generator for 5 hours. Still won't start. Any suggestions would be greatly appreciated!!!<br>[/quote]<br><br>I would suspect lift pump/injection pump combo.<br><br>If the lift pump is weak or not working, MAKE SURE that the injection pump gets replaced as well! Otherwise it will fail!<br><br>I have had this happen 3 times already...<br><br>Hope its under warranty, or that I end up being wrong about the lift pump, best of luck to you...
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
notpowerSTROKIN
42
Nov 10, 2007 09:02 AM
badme
Feb 28, 2007 07:45 PM
