truck misses when reving up but idles fine, smokes white alot!
Old Sep 14, 2009 | 11:05 AM
kyle_truck_pull's Avatar
Exclamation truck misses when reving up but idles fine, smokes white alot!
i have a 2000 dodge, it smokes white really bad at idles and when reving, it misses bad and wont hardly rev up, any ideas? havent check fuel press. yet
Old Sep 14, 2009 | 12:12 PM
rebal's Avatar
check your fuel pressure ,change filter ,check codes . thats were I would start, come back and let us know
Old Sep 14, 2009 | 09:14 PM
yeah thats my plan, but just tryin to get things gathered to check fuel press. i dont have anything to tap into the fuel system on a 2000, so i will check that and let you guys know, thanks
Old Sep 16, 2009 | 12:21 AM
hekroh's Avatar
So what did you find.. I had this problem a couple of weeks ago, after I had let my truck sit in the shop for 3 weeks while getting the AC fixed, inspection and some other stuff.. When I got it back I must have had a build up of water in the fuel tank.. Changed the fuel filter and after the 3rd start she runs like new again.. Got to love the Cummins..
Old Sep 16, 2009 | 10:24 AM
had 12-13psi fuel press. no codes with scan tool, changed filter, and it still white smokes a lot and starts missing around 1300 rpms. i went through and bled the injector lines and it will now rev alittle better but not much and it misses and smokes bad. so im not sure what to do now. thanks anyone!
Old Sep 16, 2009 | 11:43 AM
dieselfreak21's Avatar
Might be injectors or VP 44 issue. Sounds like injector could be culprit since you have nocked out most of the easy stuff.
Old Sep 16, 2009 | 12:50 PM
rebal's Avatar
it could be your Vp 44 they can still go bad with out throwing a code But first I would check all your wires and grounds a bad connection can cause you grief
Has the truck ever done anything weird or out of the ordinary before?
Old Sep 16, 2009 | 03:42 PM
just bought the truck for a prodject, it didnt run very good, i just cant get the miss to go away and it wont hardly rev up, it will rev up to around 2200, but sounds horible. is there a way to check the injection pump press. or the injectors? im gonna get another gauge and check fuel press. again just to make sure, i did get a code out of the truck when using the "key switch" it was for the fuel level sens but i dont think that would cause my problem, or maybe
Old Sep 17, 2009 | 12:29 AM
rebal's Avatar
you can pull the injectors and take them to a shop and pop test them .also when its running crack the injector line 1 at a time see if you can isolate the miss to a cylinder . see if it looks like your getting the same amount of fuel at each hole and If you haven't already, unplug any programmers on it ,that might be causing it
Old Sep 17, 2009 | 12:35 AM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
Class mate has the same truck, with same issues, poor truck has been neglected ALL its life. I guess I'll tell him to start with a filter. if he has the $$$$.
Old Sep 18, 2009 | 06:54 AM
i already cracked injectors one at a time and i do think that number two wasnt getting as much fuel as the rest, but when i cracked it the cylinder still dropped, i really think my vp44 is going bad, but i guess theres no good way to test it? is there?
Old Sep 20, 2009 | 01:02 AM
kennyhammond's Avatar
i dont know if it will matter but for some odd reason i am thinking you should look below the fue filter and there is a bleeder and crack that and get some diesel in a clear (clean cup) and see if it has any water.... other than that i would say that the vp444 can be the prob... let me know what you come up with on the cup issue....
13ALPHA
24
May 4, 2012 01:15 PM
fatt
Mar 8, 2011 12:05 AM
Tazman
Jan 26, 2010 06:38 AM
aron5823
Jun 24, 2008 11:42 PM
