transmission problem
Old Jun 7, 2009 | 07:07 PM
uber_dzl's Avatar
Hello,
My brother and I decided it was time to upgrade his transmission when his truck kept popping out of lock-up sooner and sooner. Initially under hard acceleration, then accelerating up hill, then just normal acceleration at 40mph it would come out. Anyway, we bought a triple-disk converter and a 'towing' valvebody. Installation went fine for both with no hiccups, but we did find what seemed to be about an inch long piece of a snap-ring. We chose to ignore this because the truck had been shifting perfectly fine, just wouldn't hold lock-up (figured just the converter was the issue). Well after everything is buttoned up and the fluid is in (let it idle in neutral a bit to get fluid circulated), we get excited to finally get power to the ground.
Heres the problem:
Put it in reverse and back out of the drive way, everything good so far. Put it in D and truck stalls quickly and shuts off. Started right back up and put it in D and truck starts off in third gear. We can manually put the truck in 1, 2, and D(3rd in this case), but the transmission will not shift on its own nor go into overdrive or lock-up. We adjusted the bands to spec, as well as the shift linkage and still no dice.
So in an attempt to isolate the problem, we install the old valvebody which was not broken before. We test drive again and same problem, so now we are confused and frustrated.
Truck: 1999 SRW 3.54 rear , 47re, previous owner installed banks high ram and seems to have tuned the ecm somehow because truck smokes a bit under hard accel and has a dr.performance bumper sticker(dont know if the dr.performance tune? is installed) had overboost codes.
Please provide any information that may help, it will be greatly appreciated. Thanks
Old Jun 7, 2009 | 10:51 PM
uber_dzl's Avatar
somebody? please...Im clueless
Old Jun 8, 2009 | 06:50 AM
Redliner's Avatar
Check the speed sensor on the rear of the trans housing. May not be reading true causing it not to think its moving therefore no shift....
Old Jun 8, 2009 | 11:21 AM
uber_dzl's Avatar
would that throw a code?
Old Jun 8, 2009 | 11:26 AM
uber_dzl's Avatar
the truck does have 180k miles, could the new valvebody with its higher pressure vs the old worn one have knocked something loose or forced something already on its last leg to break?
Old Jun 15, 2009 | 10:56 PM
wesley64's Avatar
i am in the process of a 47re tranny rebuild.i found broken snap ring pieces as well.turned out to be from the over drive clutches.i lost overdrive and reverse.
brett
2002ram 2500 diesel
Dauntless
15
Aug 30, 2016 08:37 PM
TGCTD
Jun 25, 2004 09:47 PM
dogman
Dec 27, 2003 07:06 PM
jec3
Jun 9, 2003 01:35 PM
NWDave
Nov 24, 2002 09:25 PM
