Transmission drain plug
I put a drain plug in mine but I took my pan off and welded it in. I was concerned about the pan being thick enough to have enough threads to hold. My pan was easy to get off and I needed to change the fluid anyhow. I know its messy to do this but after adding the lug its easy and not messy.
Yep, no way the pan is thick enough to tap, leaves you pulling pan anyway, and using a bulkhead type plug or welding one to the pan.
I never had any luck with the bulkhead style not loosening up.
Weld or get an aftermarket pan with increased capacity and a plug already in it.
mstep3
Jun 29, 2009 03:15 PM
mjsandt
Jul 22, 2008 04:21 PM
