Transmission or ?
Transmission goes into Reverse, but no power?
I have a 99 2500 24v Diesel. I'm having these three symptoms which I think are transmission related, but I need help narrowing down what area of the tranny:
1) Sitting at a stop on slight grade, my idle sounds high, when I take my foot off the brake it accerates forward (usually it would hold till I applied gas).
2) Shifting from N into Reverse or Drive, it clunks into gear, and sometimes stalls going into drive.
3) My lastest problem, no power in reverse. My RPM's go up, but I have no torque/power.
Am I dealing with transmission, computer or something in between.
Thanks!!!!!!!!!!!!
Thanks!!!!!!!!!!!!
Last edited by ak_floater; Jul 17, 2008 at 01:11 PM. Reason: Title is needs more info
It has been a while since heard this one. From description, it sounds as if cnverter is trying to lock up. If it were a manual it would be described as if did not have clutch adequatelly released and diesel responds to load by adding fuel to maintain RPM. The leak area is front pump leaking into converter circuit or bushing bad..
Dauntless
15
Aug 30, 2016 08:37 PM
