Transfer case leak
Transfer case leak
Transfer case is leaking on the truck in sig. I have tried new seals for the output shaft, to no avail. It is leaking from the case halves. Has anyone else had this problem? The thing I want to know is if I can pull the rear cover off with the case in the truck, or am I going to have a bunch of parts spring out on me? I can get it apart and re-seal it, but I dont want a bunch of parts on the ground...
Yank it out of the truck its really easy. I pulled mine out today it took maybe a half hour to do. The case is easy to split and everything is very straightforward when you have it on a bench. I had never been inside one of these before today and I had no probems figuring it out. Later, Blair
take it out!!!!!!!!
its easy, just the driveshafts, shifter linkage, a vacuum plug harness, and 6 bolts.
sit it on the workbench and remove the 4 bolts holding the tail shaft extension on, remove it.
take the snap ring off the shaft thats resting on the bearing, then unbolt the case making note of the length of the bolts and their location.
now you can lift the rear part of the case off with the oil pump attached and pickup should stay attached to the pump.
now clean and reseal with a good quality RTV, the reassemble
02.5 here so no vaccum BS. What position should I have it in when I take the rear cover off on the bench? Sorry for the detailed questions, I have never taken a chandrive apart before. Had a dana 20 and 300 apart before during a jeep adventure, but no chaindrives.
Lightman
16
Jan 21, 2004 10:46 PM
