Trans temp gauge how to?????
Old Dec 11, 2007 | 02:22 PM
xzaq103's Avatar
Just got a trans temp gauge plan to install it in the coming weeks. I have two questions first of all. All I got was the gauge what sending unit do I need? Second where/how should I hook it up? I’m completely new to the auto world. So any advice is appreciated.
Chris
Old Dec 11, 2007 | 02:52 PM
John Faughn's Avatar
Not sure what yrs , my 94 has a inline temp sensor , I disconnected the factory connector , put a 1,000 ohm resistor to those 2 connections , this fools the computer into letting the trans shift 4th & OD , before trans gets to about 40*F , then put sensor in that hole , it does not sound right , you should have got a sensor with gauge , they need to be calibrated to work together , use the stock sensor to match threads .
Old Dec 11, 2007 | 03:10 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Yeah, like mentioned above, the new gauge should have come with a sender. I'd call the place where you purchased it from and ask for the rest of your product.
Old Dec 11, 2007 | 04:30 PM
Fishin2Deep4U's Avatar
As mentioned, you'll need a sender. Some are matched the gauge, some are not.
I would recommend putting the sender in the output (hot) line. Many monitor temp in the pan. But I want to know the peak temps of my fluid. After all, that is an indication of he lifespan of the fluid.
Some use the test port in teh trans. This is not a good location due to a lack of fluid flow.
The pan and the port will react much slower to temperature swing. So, you may not see that very high fluid temp until it's too late.
Dave
Old Dec 11, 2007 | 10:23 PM
xzaq103's Avatar
i baught it used so any ideas on where to get one?
Chris
Old Dec 11, 2007 | 11:10 PM
chainzaw's Avatar
Well first off what brand gauge did you buy? We can't refer you to a good sending unit as (listed above) if we don't know your merchandise.
Help us help you!
Old Dec 12, 2007 | 09:18 AM
xzaq103's Avatar
Its made by hewitt industries. I fiund a sensor on there site for somthing like 12.00.
Chris
1985cucv
Feb 18, 2010 02:03 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
