Trans pan gasket - mag-hytec
Old May 28, 2009 | 07:33 PM
scow1's Avatar
I had a new trans installed and Im leaking a bit of ATF from the front of the pan. I have a feeling the gasket could be bad. The trans has a mag-hytec double deep pan on it. Do you think I should get a mag-hytec gasket or just a normal napa trans gasket?
Plus napa has two different sizes if I went with them: 15" L x 11.5" W x .09" H or 14" L x 11.5" W x .067" H
I have no clue which to buy now rubber or cork?
Old May 28, 2009 | 11:11 PM
raychem's Avatar
Go to the dealer and get yourself the rubber molded gasket used from 2003 and up. It should be the last one you buy. It will run you 25-35 dollars or so.
Richard
Old May 30, 2009 | 02:08 PM
Beach n Dodge's Avatar
I have the same pan, and my tranny was built last year and they used a cork gasket and started leaking in a week or so...They put a rubber one on so far so good
Old May 30, 2009 | 02:16 PM
scow1's Avatar
Thanks Beach N Dodge I will try a rubber gasket.
Old May 30, 2009 | 04:21 PM
J BODY's Avatar
Richard
Screw that rubber gasket and take Richards advice!!!!!!!!!
Old Jun 1, 2009 | 12:19 AM
dozer12216's Avatar
With the molded gasket you get additional bragging rights. Gets my vote. It is not troque sensitive as most cork and rubber gaskets are.
EverydayDiesel
Nov 11, 2007 09:33 AM
redhornet
Jul 22, 2007 09:46 PM
texasram2500
May 21, 2007 08:01 AM
Dodgezilla
May 24, 2006 09:00 PM
Johnny
Apr 15, 2004 02:10 PM
